Old 07-21-2024, 07:24 PM   #1
fourfords
fourfords's Avatar
Default Model a Heater
When I bought my little Roadster earlier this year, it has a 2" hole for a heater in the passenger side of the firewall. I will be looking for the manifold and heater cover here soon. I have learned so far that there are a few manufacturers. I guess my main question is: Will all of the manifolds/Covers line up with the existing hole in the firewall? is this an issue? what else do I need to know before I start spending my hard-earned money? I figure now's the time during the summer to start the search.
fourfords is offline   Reply With Quote
Old 07-21-2024, 07:41 PM   #2
Gene F
Gene F's Avatar
Default Re: Model a Heater
Do you even see yourself driving in weather where you'd use a heater. I mean it is a roadster....?
Gene F is offline   Reply With Quote
Old 07-21-2024, 07:58 PM   #3
Ray in La Mesa
You will very lucky to find a manifold heater to line up with your existing hole.
Ray in La Mesa is offline   Reply With Quote
Old 07-21-2024, 08:07 PM   #4
Jerry in Shasta
Jerry in Shasta's Avatar
I have this idea of putting a hot water heater under the seat of my roadster.
I would use a engine oil cooler as the radiator, with 12 volt computer fans blowing out cuts in the front of the seat riser.
There is more to do but thats the idea
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 07-22-2024, 07:49 AM   #5
nkaminar
nkaminar's Avatar
My car came with a blanket that is heated by the battery/alternator. It has a cigarette lighter plug and my car has socket for that. The socket was in the back for the passenger in the back seat.
Old 07-22-2024, 09:11 AM   #6
Wick
Wick's Avatar
Depends on what your exhaust manifold looks like, most likely it had a autolite set up.
Wick is offline   Reply With Quote
Old 07-22-2024, 09:48 AM   #7
rfitzpatrick
Move to South Florida!!!
rfitzpatrick is offline   Reply With Quote
Old 07-22-2024, 12:51 PM   #8
Charlie Stephens
The winters in Southern California are brutal. I think I would just fill the hole. Remember you are going to be getting heat through the firewall unless you have a firewall insulation pad (non original).
Charlie Stephens
Old 07-22-2024, 08:19 PM   #9
burner31
burner31's Avatar
These work great, but some units can tend to be on the noisey side
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 07-23-2024, 03:46 AM   #10
old31
I am guessing you have a 12 volt?
Old 07-23-2024, 09:58 AM   #11
Fullraceflathead
Fullraceflathead's Avatar
Avoid the high maintenance models at all costs!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 07-23-2024, 10:38 AM   #12
rotorwrench
rotorwrench's Avatar
A person can purchase an access hole cover like these.
https://www.mcmaster.com/products/ho...losure-plugs~/
The alternative is to find some same thickness cold rolled steel. It's likely 16-gauge or so. Fabricate a patch to fit closely in the hole and weld it in there. If you're not a welder then find someone who can. The caveat is that the fuel tank has to be removed to be safe.
The exhaust type heat exchangers also have a caveat. If they leak then you get carbon monoxide jn the cabin with you. A person should use an aviation type exhaust gas detector in the cabin. They make chemical types that stick on to a visible surface for easy observation.
I wouldn't want a heater in a roadster. They get warm enough without one even if it is an open car.
Old 07-23-2024, 10:56 AM   #13
CatMan1
JB
I've thought the same thing could be possible. The heater in a 1947 Chevy sedan would be a good fit.
CatMan1 is offline   Reply With Quote
Old 07-23-2024, 12:22 PM   #14
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
My '31 Tudor had the manifold heater at some time because it has the tube thru the firewall for heat.
I found on line a styrofoam ball of the same diameter and used it to fill the tube to keep heat and critters out of the cabin.
fried okra is offline   Reply With Quote
Old 07-23-2024, 12:27 PM   #15
figment
If you end up not having a heater you can always get a Heater cover that came with all the manifold heaters that closed or opened off the heater and would direct the heat . . They fasten with I believe 2 screws . I have one that I would part with . I have seen many of them at some of the swap meets .
figment is offline   Reply With Quote
Old 07-23-2024, 02:08 PM   #16
fourfords
fourfords's Avatar
6 volt positive ground. I go on tours year round based in Southern California. Winter time in the morning in this open car is somewhat uncomfortable. I'm trying to learn what I can before spending $$$. Thanks for all the different perspectives and information.
Old 07-23-2024, 02:13 PM   #17
fourfords
fourfords's Avatar
"Moving to Florida": Uprooting my entire life to accommodate a two inch hole in a firewall of a 95 year old car is a bit extreme. Maybe for other reasons!!!
Old 07-24-2024, 10:12 AM   #18
Afordman31
Afordman31's Avatar
Someone asked me why I have the Autolite heater in my Speedster, My reply,,,because my wife's feet get cold!
Afordman31 is offline   Reply With Quote
Old 07-24-2024, 06:37 PM   #19
fourfords
fourfords's Avatar
I'll go with that!!
Old 07-24-2024, 08:01 PM   #20
700rpm
700rpm's Avatar
@four fords: if you get a cover for that manifold heater, remove it in hot weather driving. Cover on can roast your condenser.
Ray Horton, Portland, OR
