Old 07-20-2024, 02:16 PM   #1
FrankWest
FrankWest's Avatar
Default convert 1932 starter to 1933 starter
Can a model B 1932 starter be converted to a 1933/34 model b starter
FrankWest is offline   Reply With Quote
Old 07-20-2024, 07:42 PM   #2
koates
Default Re: convert 1932 starter to 1933 starter
Frank, the difference is the battery terminal copper stud where the B model is a flat contact and the 34 is a threaded terminal for the cable to go onto. To change to the later terminal the starter would need to be dismantled to solder the later terminal stud to the field coils. Maybe a good old auto electrician could do this job for you. You need to find a terminal stud as well. Regards, Kevin.
koates is offline   Reply With Quote
Old 07-20-2024, 08:33 PM   #3
DavidG
DavidG's Avatar
The change was made late in the '32 model year the late '32-'41 four-cylinder stater motors are not that scarce.
Old 07-21-2024, 04:18 AM   #4
FrankWest
FrankWest's Avatar
Thanks, I will search for a replacement.
Old 07-21-2024, 04:21 AM   #5
FrankWest
FrankWest's Avatar
Thanks. I will forget about it. When I bought my car, the same guy sold me a replacement model B motor, unfortunately that motor had the 1932 starter attached.
