Old 07-10-2024, 07:40 AM   #1
fundytides
fundytides's Avatar
Default Outside Mirror
I am looking for an outside mirror to use on my 31 Standard Roadster. All I see advertised are the ones that mount in the pre-drilled holes in Deluxe Roadster stanchions or the ones that mount on the side mounted spare tires, which I don't have. Am I going to have to drill and tap my stanchions? What do you guys use or are there no Standard Roadsters left any more?
fundytides is offline   Reply With Quote
Old 07-10-2024, 07:59 AM   #2
JBill
Default Re: Outside Mirror
I put a couple of those stick on mirrors on my windwings. Better than nothing.
JBill is offline   Reply With Quote
Old 07-10-2024, 08:14 AM   #3
alexiskai
alexiskai's Avatar
Yeah, windwing mirrors on my 35-B.
Old 07-10-2024, 09:32 AM   #4
fundytides
fundytides's Avatar
Sorry, no windwings either.
Old 07-10-2024, 10:00 AM   #5
alexiskai
alexiskai's Avatar
If your lower stanchions attach to the body using screws that are 5/16-24 (not 5/16-18), you could install this in place of one of them.
https://www.snydersantiqueauto.com/p...7140&cat=41734
If the screws are 5/16-18 or something else, potentially you could take this one and machine down the existing post and tap it for what you need. I realize that's a bigger job.
https://www.snydersantiqueauto.com/p...7139&cat=41734
Old 07-10-2024, 12:57 PM   #6
jg61hawk
Don't they all have the screws that hold the stanchion to the dash....I don't know...I attached my mirrors as shown in the attached photos.
jg61hawk is offline   Reply With Quote
Old 07-10-2024, 04:45 PM   #7
Herb Concord Ca
My standard stanchions that I bought on this swap meet section years ago, had a hole drilled and tapped in the left side stanchion. Use it to mount my mirror.
Herb Concord Ca is offline   Reply With Quote
Old 07-10-2024, 05:48 PM   #8
fundytides
fundytides's Avatar
Thanks fr all the interest and input. Looks like I may have to resort to drilling and taping the post.
Old 07-10-2024, 06:23 PM   #9
Synchro909
Synchro909's Avatar
On my Phaeton, I made a fitting that attaches to the place where the windscreen pivots. I mounted a couple of motor cycle mirrors on them and have used them that way for about 15 years. No drilling anything on the car, no modifying. Easy.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 07-10-2024, 07:02 PM   #10
Bruce of MN
Bruce of MN's Avatar
Photo, please.
Bruce of MN is offline   Reply With Quote
Old 07-11-2024, 06:34 AM   #11
fundytides
fundytides's Avatar
I think I will go this route. Where is the hole located (how far up from the wingnut) and does this location work out alright for you? Given the choice, would you locate it higher or lower? Thanks
Old 07-11-2024, 08:20 AM   #12
Planojc
Planojc's Avatar
Get in the car and hold the mirror at the best height for you and mark it. I had to drill the passenger side stanchion on my deluxe and it works fine.
Planojc is offline   Reply With Quote
Old 07-11-2024, 08:39 AM   #13
David in San Antonio
David in San Antonio's Avatar
Synchro, Please post photos of your fitting.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 07-11-2024, 03:28 PM   #14
nkaminar
nkaminar's Avatar
Here are a couple little safety tips.
I have two outside mirrors on the driver's side. The lower one is aimed at the driver's side rear fender. I use that when backing into my garage and backing into parking spots.
The other mirror on the driver's side is aimed at my blind spot and the outside mirror on the passenger side is aimed at the other blind spot. The inside mirror is aimed to the center rear. That way I have all views covered and don't have to turn my head to check the blind spots. This arrangement has saved my ass more than once.
Old 07-11-2024, 06:45 PM   #15
Synchro909
Synchro909's Avatar
I'll see what I can do. I don't even own a mobile phone or digital camera and have no idea on how to post a picture. I'll ask one of my grandchildren.
Old 07-12-2024, 11:36 AM   #16
Herb Concord Ca
Hi Fundytides, mine measures 6.5" center to center. I used a jam on the post to lock it in place. The height seems to work OK for me, I'm 5'10" tall. You can do what #12 suggested if you need to drill a hole.
Old 07-12-2024, 08:51 PM   #17
fundytides
fundytides's Avatar
Thanks for the measurement Herb
Old 07-13-2024, 10:33 AM   #18
Synchro, Thank you. At our Alamo A club meetings your name comes up in conversation and your multi-thousand mile trips are admired.
Alamo A’s Club
Old 12-07-2024, 08:26 AM   #19
fundytides
fundytides's Avatar
Just an update in case anyone else is doing this. I completed the mirror installation yesterday by drilling and taping the original standard stanchion. The drill chart that came with my chain store tap and die set, said to use a 3/8" drill for my 7/16"-20 mirror post. After doing that, I tried to tap the hole with no success. The tap just wouldn't start. I called a machinist friend of mine and he said I would probably need a better quality tap (which he has). I took the stanchion to him and he had difficulty starting his tap as well. He checked his drill chart and it called for a 25/64" drill for the 3/8"-20 tap. After using this drill, the tap started and the job was successful. Two lessons learned-use good quality tools and make sure you have the right info. The chain store tap and the drill reference may have worked on softer metal but not on the stainless used by Henry. Apparently there were many areas where he did not sacrifice quality.
Old 12-07-2024, 11:08 AM   #20
Fullraceflathead
Fullraceflathead's Avatar
I think you meant 7⁄16 — 20 on your tap.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
