Old 07-07-2024, 09:16 AM   #1
Babyboomerboy
Babyboomerboy's Avatar
Default installed weather seal in trunk of 1950 Ford but can't get it to close
I got the weather seal glued in and I knew it was going to be tight but I can't get the trunk lid to close and latch. Does anyone have any ideas that would help. Thanks
Babyboomerboy is offline   Reply With Quote
Old 07-07-2024, 09:48 AM   #2
TJ
TJ's Avatar
Default Re: installed weather seal in trunk of 1950 Ford but can't get it to close
I'm no expert on 50 Fords, but is there an adjustment for the catch? If so, you can adjust the catch so the latch will engage.
Old 07-07-2024, 10:30 AM   #3
19Fordy
19Fordy's Avatar
Please post clear close up photos of your weatherstrip install and poor fitment issues.
Old 07-07-2024, 12:15 PM   #4
Babyboomerboy
Here are a few pictures.
Old 07-07-2024, 12:25 PM   #5
leon bee
Have you left the car out in the hot sun yet?
leon bee is offline   Reply With Quote
Old 07-07-2024, 12:38 PM   #6
19Fordy
19Fordy's Avatar
Thanks for posting the photos. For comparison, I hope someone would post photos of an OEM installation along with a cross section showing how the weather striping fits inside the lid and the trunk body edge.
Old 07-07-2024, 01:49 PM   #7
Babyboomerboy
Thanks for all the replies. After banging on it a lot I finally got it to latch closed. Tomorrow I will see if I can get it unlatched. Thanks again
Old 07-07-2024, 08:20 PM   #8
ford38v8
ford38v8's Avatar
Weather seals need to take a set under the compression of the closed lid or door.
Alan
Old 07-08-2024, 09:10 AM   #9
TJ
TJ's Avatar
Alan is correct.
Old 07-09-2024, 09:00 AM   #10
Mart
Mart's Avatar
You might try slackening the latch a small amount and then tightening it in small increments over time. Unless it starts to unlatch/latch as it is. Leaving it out in the sun sounds like a good idea.
Old 07-10-2024, 01:18 PM   #11
Cecil/WV
Cecil/WV's Avatar
It looks like the seal is on the body, if so, it is wrong, the seal goes on the lid and there is another u shaped piece that goes on the pinch weld on the body.
After a closer look, I see the seal is on the lid.
Cecil/WV is offline   Reply With Quote
Old 07-10-2024, 02:56 PM   #12
Don T
Don T's Avatar
The u shaped piece on the pinch weld on the body is badly out of place in the bottom RH corner. I do not know if you tried to close the trunk when it was that way? This is the normal poorly fitting shoebox trunk lid. Adjust the latch a little at a time and leave closed a few days between adjustments.
Don T is offline   Reply With Quote
