Old 07-07-2024, 06:02 AM   #1
joe 1950
joe 1950's Avatar
Default wiring a aftermarket horn with relay
what i’m trying to do is wire up a aftermarket spartan horn with a relay in a 1935 ford pickup i’ve wired relays in other vehicles i no how they work but i can’t get the horn button to ground the relay truck has one original horn that works but on this system the voltage passes through the horn to energize the coil and is grounded through the button need. wiring diagram for the aftermarket witch didn’t get with it thanks for any help i can get
joe 1950 is offline   Reply With Quote
Old 07-07-2024, 07:43 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: wiring a aftermarket horn with relay
If the relay is energized by grounding one pole of it, then it should work just fine. What type of relay do you have? Do you have a part number?
Old 07-07-2024, 08:57 AM   #3
joe 1950
joe 1950's Avatar
the relay works fine i’ve bench tested it what i can’t get is the horn button to activate the relay by grounding it when pushed
Old 07-07-2024, 10:36 AM   #4
40cpe
40cpe's Avatar
I think you need to permanently ground the relay terminal and provide the power to activate the relay through the horn button.
40cpe is offline   Reply With Quote
Old 07-07-2024, 11:54 AM   #5
joe 1950
joe 1950's Avatar
40 cpe i totally understand what you’re saying the relay has 3 terminal on it. Horn. Bat. Switch . so if i ground the switch terminal then the relay will be energize full time the truck has one original horn that works there’s power on both terminals one is bright and one dim when i activate the horn button the dim one goes out so i assume that would be the ground side those horns are wired hot all time just saying
Old 07-07-2024, 08:09 PM   #6
Bored&Stroked
So, it works when you just manually jump the 'Switch' terminal to ground? But, when you attempt to use the horn button to supply the ground, it does not work? If so, then use an OHM meter and connect one lead to the frame and the other to the horn wire and see if the button is working correctly. You should see continuity when pressing the button.
Old 07-07-2024, 08:40 PM   #7
petehoovie
petehoovie's Avatar
Old 07-08-2024, 07:54 AM   #8
Bored&Stroked
FYI - there is no power through the horn button - it goes to ground. So the relay needs to be normally open and actuated when the "switch" side sees ground.
Old 07-08-2024, 09:16 AM   #9
JayChicago
JayChicago's Avatar
Do solenoid coils care about polarity?
If the relay's solenoid coil is designed for the typical negative ground, but on our cars its positive ground, electrons are flowing backwards. Would that make the solenoid switch magnet pull backwards, opening the contacts?
JayChicago is offline   Reply With Quote
Old 07-08-2024, 09:20 AM   #10
JayChicago
JayChicago's Avatar
If the relay is designed for 12 volt, maybe 6 volts is not strong enough to pull in the relay's solenoid switch?
Edit:
Just realized you did a bench test and the relay worked. So that dis-proves both my thoughts above. Nevermind!
Old 07-09-2024, 05:43 AM   #11
joe 1950
joe 1950's Avatar
I want to thank all of you for your help the wiring diagram was very helpful i figured it out and got the relay to work with the horn button the new aftermarket market horn would work but sound was terrible so come to adjust the screw for tone only to find it was stripped out my buddy had this horn about 10 years ago so i think the warranty is off but everything works as it should thanks again
