Old 07-06-2024, 05:23 PM   #1
Wallysdog
Default Priming the oil pump on a 226 flathead
Can I insert an old distributor shaft attached to an electric drill to prime the pump?
Would it be possible to fill the crankcase by pumping break in oil through the sending unit port? Thanks.
Wallysdog is offline   Reply With Quote
Old 07-07-2024, 06:56 AM   #2
glennpm
glennpm's Avatar
Default Re: Priming the oil pump on a 226 flathead
"Can I insert an old distributor shaft attached to an electric drill to prime the pump?"
No
"Would it be possible to fill the crankcase by pumping break in oil through the sending unit port? Thanks."
Yes, this can work. Screw a hose barb fitting into this location and then fill with either a gravity fill, pressurized tank full of oil or an external oil pump in a bucket of oil. I've done the last by fabricating a plate and nipple bolted onto the outlet of a SBC oil pump. The pump is submersed in a 5 gallon bucket of oil, clamped to the bucket and running the hose to the sending port. I used an air drill with a tool like this, https://www.jegs.com/i/JEGS/555/23640/10002/-1, that engages the pump, as the bottom of a SBC distributor does, and primed it.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 07-07-2024, 07:54 AM   #3
Wallysdog
Thanks Glenn.
Jim-
Old 07-07-2024, 07:56 AM   #4
glennpm
glennpm's Avatar
Glad to help
Old 07-08-2024, 04:43 PM   #5
KiWinUS
KiWinUS's Avatar
We don’t know what year/ model engine but I don’t think you can prime oil pump on either G or H engine.
Old 07-10-2024, 08:59 PM   #6
Wallysdog
1950 Ford Custom
226 6 cyl
Old 07-11-2024, 09:20 AM   #7
KiWinUS
KiWinUS's Avatar
Originally Posted by Wallysdog View Post
1950 Ford Custom
226 6 cyl
H engine. Oil pump has gear driven off cam. Can’t prime. Remove plugs ignition off and spin engine over on starter.
Old 07-11-2024, 01:30 PM   #8
irondoctor
That’s how I do it
Usually builds pressure fairly quick
irondoctor is offline   Reply With Quote
