Old 06-30-2024, 03:50 PM   #1
C1Nelson
Default 30 Roadster Door Striker
During a recent 1300 mile trip from Idaho to Northern California and back through Oregon the door striker on my 30 roadster jammed in the latch and I had to get out of the car on the passenger side. In order to get the door open we stuck a screwdriver into the latch and applied pressure. The striker (cast ?) broke. I used a bungee cord to keep the door closed for the trip home.
I ordered a new striker and the best latch from Snyders. Upon installing the latch and the striker, the striker does not match up with the latch opening. It looks like the new striker needs to be spaced out from the door jamb? Has anybody done this, and how did you do it?
Anybody have any original strikers? Snyders says these are “perfect”. I guess my door needs pushed towards the striker ?
C1Nelson is offline   Reply With Quote
Old 07-01-2024, 08:50 AM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 30 Roadster Door Striker
Unfortunately, even the best reproduction suppliers have the occasional "turkey". That door striker is part of Snyders 1%. If you look from the top down Snyders striker (and Vintique's for that matter) has a 90 degree profile, which should be 95 degree, with the tang parallel to the mounting face. The 95 degree angle matches the angle on the latch. When it does not the striker jams.
The interchange on the striker is 1928-1932... Bob Drake makes one that is more correct, in stainless. I keep them in stock.
Karl Wescott
Wescotts Auto
503-658-3183
www.wescottsauto.com
Karl Wescott is offline   Reply With Quote
