#1 |
Last year prior to installing my lifters I noticed cracking around the bottom edge of four of them, Speedway were kind enough to refund me the set ( after 2 years ) but could offer no alternative , neither could anyone else , seems like all lifters had decamped off the planet for awhile . I ended up getting 4 units from a tractor supply company ( I had the counter jockey run his vernier over them ) as fitted to N series Ford tractors. As my knowledge regarding Ford tractors could be written on the back of a postage stamp , the question is what years , and iff they were original Ford fittment or an aftermarket thing?
#2 |
call Johnson lifter i think they made the orig ones.
#3 |
1939-1951, all The N series tractors , 9N, 2N, 8N ran those as factory fitted.
#4 | |
#5 |
If you are running any adj lifter with the end screwed out that far, that is trouble and will never hold an adjustment.
#6 |
#7 |
The reason I asked about the years and if original equipment is that in Rodger Huntington`s early 50`s book he states that Ford never offered adjustable lifters for the flathead V8 but it appears that they were available in the tractors of the era and as far as I can see were interchangeable. (. I hope someone doesn`t poke a stick in my spokes on this one. )
#8 |
There's nothing in the N series Ford tractor parts book showing
adjustable lifters. |
#9 |
My 2 cent, get a old set on a swapmeet and send them on a regrind.
I would stay away from the new stuff. Std Henrys was 45 grams aswell. |
#10 |
I read something recently that the Ford tractor lifters are the same fitment for the V8. I looked them up on a tractor website and they were listed but were currently out of stock.
#11 |
I bought some adjustables years ago for a 2N but they were solid and heavy. Go to the link and check out some of the sites they show them in stock. Some look solid and some look hollow so I would call and make sure what they are.
https://duckduckgo.com/?t=h_&q=AONN-...+lifter&ia=web |
#12 |
When I bought my Iskenderian MAX1 cam and kit (cam, lifters, and springs) from Speedway many years ago, it came with the solid body lifters. I think that's what they use these days.
#13 |
Yes , it seems mostly solid these days.
Re. Post 9. Swap meets, they might exist in the State Capital but that's 1000 miles south |
#14 |
what would set of original Johnsons be worth.
Lawrie |
#15 |
If they are needed for a regrind cam and do not have the thick headed screw, nothing. If being used with a stock cam, they seem to go for upwards of $100. The thick head ones are almost impossible to find any more. We are talking used ones here.
#16 |
What about a longer bolt in the case of a reground cam? It would not have the necked down area in the center that is compressed to create the interference fit, but with a thin head bolt screwed out that far perhaps there is room for a jamb nut. I've always wished there was room for a nut, but I have always used stock cams. You may have to roll the cam or crank to get at the nut, but not that much of a problem.
#17 |
Would lash caps be okay in a situation where they are otherwise threaded out too much?
#18 | |
Edit: Actually a lash cap would keep the screw thread better engaged into the lifter's body where the interference fit works best, so I recind my earlier comment. Sometimes you gotta be driving down the road thinking these things through!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 07-02-2024 at 11:38 AM. |
#19 |
This thread kinda meandered away from the original theme which
basically asked if anyone had any opinions of mixing and matching lifters. ( using 12 Speedway solid adjustables and 4 of N series Ford tractor solid adjustables ) photo shows the two side by side |
#20 | |
