Old 06-27-2024, 11:03 AM   #1
FrankWest
FrankWest's Avatar
Default Condenser for 1933 model B
What condenser do I use for a model b 1933 engine
FrankWest is offline   Reply With Quote
Old 06-27-2024, 01:34 PM   #2
DavidG
DavidG's Avatar
Default Re: Condenser for 1933 model B
Try Renner's Corner.
Old 06-27-2024, 02:34 PM   #3
FrankWest
FrankWest's Avatar
Thanks David. He does not have them, But I found one at allfordparts. Hope it works.
Never realized this was a unique part for model B. I wonder why model A condenser will not work on model B. I could understand why a v8 condenser will not work. These cars are more complicated than I once thought.
Old 06-27-2024, 02:53 PM   #4
J Franklin
J Franklin's Avatar
Many condensers can work on a model b ford it just won't look right.
Old 06-27-2024, 05:39 PM   #5
Charlie Stephens
You are right, they look terrible. I have even considered selling my vehicle because it's "ugly". Maybe I should put a small block Chevy in? Having said that if you can't find the correct condenser get the best Model A condenser you can buy (probably the high end one from Bratton's). Make a pig tail to go from the condenser to the distributer. Elongate the slot in the strap at the end of the condenser slightly and install it. See the attached photos of mine.
Charlie Stephens
Old 06-27-2024, 06:02 PM   #6
petehoovie
petehoovie's Avatar
Charlie Stephens
Old 06-27-2024, 09:45 PM   #7
DavidG
DavidG's Avatar
Charlie,
What's truly ugly are the way-too-long head studs.
Old 06-27-2024, 09:48 PM   #8
DavidG
DavidG's Avatar
NOS B condensers aren't very scarce and in my experience work as intended despite their age.
Old 06-28-2024, 07:54 AM   #9
FrankWest
FrankWest's Avatar
Thanks. Good to know.
Old 06-28-2024, 08:14 AM   #10
FrankWest
FrankWest's Avatar
Here is a photo of my existing condenser and mounting. I don't know if it is the proper original configuration?
Old 06-28-2024, 10:13 AM   #11
petehoovie
petehoovie's Avatar
Old 06-28-2024, 11:35 AM   #12
DavidG
DavidG's Avatar
Yours is located as original.
Old 06-28-2024, 04:11 PM   #13
FrankWest
FrankWest's Avatar
wow, beautiful restoration
Old 06-28-2024, 04:37 PM   #14
petehoovie
petehoovie's Avatar
Old 06-29-2024, 03:13 PM   #15
Terry,OH
Terry,OH's Avatar
I believe this is what you want B-12300, 0.20 to 0.25 mfd about the same rating as the 46-48 6 Cyl condenser which may be offered by NAPA, but it would not have the mounting bracket.
Old 06-29-2024, 03:57 PM   #16
petehoovie
petehoovie's Avatar
Old 06-29-2024, 05:57 PM   #17
J Franklin
J Franklin's Avatar
If it fits the hole you could epoxy the old mounting bracket on it.
Old 06-30-2024, 06:12 AM   #18
Terry,OH
Terry,OH's Avatar
The mounting bracket is an electrical conductor Suggest soldering it on to another condenser, if need be.
Old 06-30-2024, 08:22 AM   #19
Planojc
Planojc's Avatar
Try the Model a suppliers like Snyders, Brattons, etc. since many Model A's are running B engines.
Planojc is offline   Reply With Quote
Old 07-01-2024, 02:36 PM   #20
FrankWest
FrankWest's Avatar
https://www.youtube.com/watch?v=Bu-A8YfC4w0
