Old 06-22-2024, 01:34 PM   #1
rockfla
rockfla's Avatar
Default Anyone run into this?
Installing the flywheel today and found one bolt hole for the pressure plate is 3/8-16 not 5/16-18, evidently it was stripped and re-tapped larger. The issue now is a 9/16!socket won’t fit because the bolt head is too close to the flywheel & you cannot get any wrench on the head either. Anyone have any reason why I could use a button head socket cap screw in its place??? It will give a good baring surface, be easy to use an Allen socket to make sure it’s tight PLUS it’d be stronger material than the other 5 5/16 bolts in there now. The head will be low enough for any possible clearance issues.
Old 06-22-2024, 02:02 PM   #2
glennpm
glennpm's Avatar
Default Re: Anyone run into this?
Seems like a good solution. Instead of "won’t fit because the bolt head is too close to the flywheel", don't you mean too close to the pressure plate?
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 06-22-2024, 03:51 PM   #3
cadillac512
cadillac512's Avatar
That'll work just fine.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 06-22-2024, 03:55 PM   #4
34fordy
34fordy's Avatar
There are various 3/8-16 header bolts with a smaller hex in 6 and 12 point hex.
34fordy is offline   Reply With Quote
Old 06-22-2024, 04:04 PM   #5
rockfla
rockfla's Avatar
Glennrpm
The pressure plate sits down inside the flywheel so the bolt head clears the flywheel BUT is so close to it the socket will not fit between the head of the bolt and the flywheel.
34Fordy
I hadn’t thought about a 12pt head, I sell “industrial” fasteners and thought of a button socket cap as I sell them and have them in stock, 12pt heads “generally” are more “automotive” from my work perspective SO not as front and center in my mind as perhaps they should be.
Thanks!!
Old 06-22-2024, 04:10 PM   #6
rockfla
rockfla's Avatar
Glennrpm
Here’s what I have
Old 06-22-2024, 04:45 PM   #7
34fordy
34fordy's Avatar
Hey rockfla,
Pictured here is a 1” and a 13/16”. Send me a Pm with your name and address and I will send both to you if one would work. 7/16 hex and 9/16 washer tang.
Old 06-22-2024, 04:55 PM   #8
kurt v
they should have a shoulder on the bolts
kurt v is offline   Reply With Quote
Old 06-22-2024, 05:06 PM   #9
34fordy
34fordy's Avatar
And they do.
Old 06-22-2024, 05:26 PM   #10
rockfla
rockfla's Avatar
Originally Posted by 34fordy View Post
Hey rockfla,
Thank you very much
Old 06-22-2024, 09:27 PM   #11
petehoovie
petehoovie's Avatar
Originally Posted by rockfla View Post
Glennrpm
Here’s what I have
Old 06-22-2024, 09:28 PM   #12
petehoovie
petehoovie's Avatar
Hey rockfla,
And they do.
Old 06-22-2024, 09:39 PM   #13
Ol' Ron
Ol' Ron's Avatar
I don't think there's any problem here. Done worst in thepast.
Gramps
Old 06-23-2024, 06:06 AM   #14
Ggmac
I admit to not reading the entire post but if you’re in a hurry , sbc header bolts are whats pictured . Readily available at any part store .
Ggmac is offline   Reply With Quote
Old 06-23-2024, 06:10 AM   #15
glennpm
glennpm's Avatar
Glennrpm
Here’s what I have
Thanks for the photos. I see the problem now. Either the button head or the header bolts will work fine.
Glenn
