#1 |
How to start a '28 Ford Model "A" the old time way.
From Stoney Lonesome Productions™ and Thanks for watching! https://vimeo.com/435389638 Stoney Lonesome Productions™ short,comic,reel,WATCH...Old-Time,silent moving pictures: https://vimeo.com/channels/stoneylonesome |
#2 |
I guess thats why my A wont start, I am not waring those fancy gloves.
#3 |
Nice truck.
#4 |
While I am not a proponent of using two hands, I do think it is worth mentioning that everyone should take note of this "Cranker's" hand position. If the engine were to 'kick', it should be able to release from his hands suddenly without jerking a thumb off.
One other thing that I learned the hard way that ultimately caused me to have Rotator Cuff surgery on my cranking arm is that the technique should not be to jerk the crank quickly thru rotation, but just to pull slowly and steady past the piston cycle. Since the cranking stroke is generally ¼ of a turn -or one piston compression cycle, then there is not any advantage to jerking it quickly. This is why even petite ladies back in the day were capable of hand-cranking a Model-A (or Model-T) engine. |
#5 |
Not sure what the choke did for him since he pull and released it??
The Master Cylinder Enjoying life at the beach in SoCal... |
#6 | |
Sometimes starting the Ts at Greenfield Village I have to give the choke a 'blip' while it's cranking and then they will fire right up. It's usually when it's been cranked and started then died. Very Respectfully, jason
Barnstormers VSC- Celeritate Est Vita Battery Fabrication Technologist- Ford Motor Company Antique Vehicle Mechanic- Greenfield Village Sometimes Docent - Ford Piquette Avenue Plant Member #347- Early Ford Registry rileyracing on the HAMB |
#7 |
I’ve never tried hand cranking our car cold (I never really thought about that until now), but I usually have to blip the choke when using the electric starter when the car is cold. After the engine is warm, I can hand crank it without choking. Brent is right for our car. A slow crank of about a 1/4 rotation is usually all it takes.
We are blessed. Our car has always started easily. Sent from my iPhone using Tapatalk |
#8 | |
2024-2026 MAFCA Technical Director |
#9 | |||
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 06-21-2024 at 11:11 AM. |
