Old 05-31-2024, 08:41 AM   #1
Ten1nis
Ten1nis's Avatar
Default Clutch chatter
My 30 pickup has clutch chatter when moving from a dead stop both forward and reverse. What can I do to smooth my engauagement?
Ten1nis is offline   Reply With Quote
Old 05-31-2024, 08:55 AM   #2
ArtimusGordon
Default Re: Clutch chatter
The FLYWHEEL has probably has oil or grease on it. Needs to have oil products cleaned OFF.
ArtimusGordon is offline   Reply With Quote
Old 05-31-2024, 08:57 AM   #3
ArtimusGordon
Flywheel probably has grease or oil on it. Flywheel needs to be cleaned!
Old 05-31-2024, 09:03 PM   #4
Synchro909
Synchro909's Avatar
That's one possibility.
That's one possibility. (joking)
An easier thing to check is "Are the engine mounts tight?"
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 05-31-2024, 09:25 PM   #5
old31
oh funny one synch! It took me a while.
Old 06-01-2024, 12:30 AM   #6
700rpm
700rpm's Avatar
How to do that with engine in car?
Ray Horton, Portland, OR
Old 06-01-2024, 06:07 AM   #7
nkaminar
nkaminar's Avatar
The best thing is to take the clutch apart, either by removing the engine or removing the rear end and transmission. It is easier for me to remove the engine because then the clutch is accessable and I don't have to be working under the car or through the hole where the floor boards were. I don't have a lift.
You could try some spray parts cleaner with the clutch peddle held down while the engine is running. That would be a pig in a poke. I have no idea if it would work. And that may not be the cause of your clutch chatter. A block of wood cut to the right length and wedged between the clutch peddle and the brake peddle will hold the clutch down. Do not breath the spray. A carbon filter face mask is a good idea.
Old 06-01-2024, 09:48 AM   #8
47topless
47topless's Avatar
The two surfaces, clutch disk and flywheel, are not mating properly. Before taking the clutch apart, I would at least try to "mill" the disk by riding, (smoking) the clutch for a few seconds. That would also burn off any "foreign" materials on either surface. No harm to try this before going to all the work of accessing the clutch.
As suggested above, I would check the motor mounts first.
Good luck.
47topless is offline   Reply With Quote
Old 06-01-2024, 09:26 PM   #9
JayJay
Yup. When I purchased my ‘31 a couple of years ago it had ugly chatter. Upon examination I found one of the nuts on the bolt through the Float-a- Motor rubbers was about to fall off. That mount was loose as a goose. New rubber discs and some jam nuts - problem solved.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 06-02-2024, 09:00 AM   #10
Afordman31
Afordman31's Avatar
I had the same problem with my Pickup, Was caused from over greasing the throwout bearing.
Afordman31 is offline   Reply With Quote
Old 06-02-2024, 10:56 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Take the clutch hand holed cover off and check for contamination with transmission oil / motor oil. If you find the clutch is contaminated, try douching it liberally with brake cleaner while a friend operates the clutch pedal.
If this fails to stop the chatter, it will be necessary to remove the clutch and flywheel for a thorough cleaning. I suspect the transmission may have been overfilled.
Bob Bidonde
