05-08-2024, 03:18 PM | #1 |
Help needed to identify Bell Housing
can anyone tell me what this bellhousing exactly is from? i see marked inside T9-1&1/2. thank you for any help.
05-08-2024, 03:36 PM | #2 |
Re: Help needed to identify Bell Housing
Making the simple complicated for over 30 years. |
05-08-2024, 03:45 PM | #3 | |
thank you’d or the reply but my
bell housing doesn’t have the starter cut out and small inspection plate as what you posted in that picture. i dont have those casting numbers also. i think mine is different? Quote:
05-08-2024, 05:06 PM | #4 |
Certainly different. Look how high the bores for the throwout fork shaft are compared to what we usually see.
05-08-2024, 05:34 PM | #5 |
I don't think that is a Ford. They used the same or similar transmissions
in Studebaker, Dodge, Mack and who knows what other trucks. |
05-08-2024, 06:08 PM | #6 |
05-08-2024, 06:32 PM | #7 | |
05-08-2024, 06:34 PM | #8 | |
05-08-2024, 07:37 PM | #9 |
Its not a Ford its missing the clearance for the starter cover on the oil pan. Also there's some missing bolt holes as well as the dowl pin alignment holes. And the throw out bearing shaft pivot points are not in the same location as the Ford Flathead Hogs Head.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-08-2024, 09:23 PM | #10 |
Cas3 has it. It's for an SAE flywheel housing.
https://swiftequipment.com/sae-housing-flywheel-sizes/ |
05-09-2024, 05:39 AM | #11 |
im still clueless what this is for
05-09-2024, 06:05 AM | #12 |
The Borg-Warner T9 transmission was used in lots more applications than just Ford trucks. I have seen reference to them in many other old trucks, in various tractors, and in industrial engine applications. That clutch housing looks to have an SAE bolt pattern ring on one side an industrial or tractor clutch setup, and a T9 bolt pattern on the other side. Not a Ford part at all.
05-09-2024, 02:13 PM | #13 |
Not being a Ford part looks like your not going to be able to sell it here on the Barn.
