Old 05-05-2024, 07:53 AM   #1
Ziggster
Default Interesting Flathead Marine Engine
Just came across this marine flathead engine for sale on FB.
Ziggster is offline   Reply With Quote
Old 05-05-2024, 02:25 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Interesting Flathead Marine Engine
Old 05-05-2024, 06:54 PM   #3
GB SISSON
GB SISSON's Avatar
Now that is REALLY cool to me. Paragon gear is/was in Taunton Massachusetts, near where my dad grew up. I'd love to have first dibs if you only want the engine part.
Old 05-05-2024, 08:33 PM   #4
tubman
tubman's Avatar
"C69A"? Isn't that a Canadian engine?
Old 05-05-2024, 08:51 PM   #5
Newc
Newc's Avatar
Yep, and many of those are ww2 surplus. Have one in my '48 114X. 3 3/16 relieved from factory. Canadian intake with the provision for a tall oil fill. Pull the heads. The extra oil port was used for an oil cooler in Canadian tracked vehicles [carriers]. Some ww2 Military fellows would like to have that eng. Correct eng for my avatar. Newc
Old 05-06-2024, 01:55 AM   #6
richard crow
if that eng was used in salt water you will need king kone to take it apart
richard crow is offline   Reply With Quote
Old 05-06-2024, 04:43 AM   #7
Ziggster
Likely. It was listed for sale in Brampton, ON Canada IIRC. Can’t get back into FB marketplace for some strange reason, otherwise I would post the link.
Old 05-06-2024, 04:46 AM   #8
mcharley40
Interesting is right I like the High and Tight Headers
mcharley40 is offline   Reply With Quote
Old 05-06-2024, 05:32 AM   #9
38 coupe
38 coupe's Avatar
It has the Canadian third oil port introduced in WW2 that some people use for "95%" oil filter conversion.
I too would be concerned about water jacket corrosion.
Old 05-06-2024, 09:21 AM   #10
woodiewagon46
If the engine was used in a salt water application it might be junk. Salt water, cast iron and heat don't play nice together. You won't find an engine rebuilder on both the north and south shore of Long Island that will rebuild a salt water cooled engine. A friend had a boat with a 1980's Ford V-8 that needed a rebuild and could not find any shop to rebuild it. All told him to replace the motor.
woodiewagon46 is offline   Reply With Quote
Old 05-06-2024, 03:31 PM   #11
Ziggster
Was able to get back into FB. Link is below. I doubt it was used on salt water, but most likely the Great Lakes or on smaller lakes in Ontario.
https://www.facebook.com/share/iD6n5...ibextid=79PoIi
Old 05-06-2024, 04:10 PM   #12
John Gibson
John Gibson's Avatar
$800 Canadian comes out to about $585 USD which isn’t outrageous given it come with a marine transmission, etc. I would think it has only seen fresh water given it’s location.
John Gibson is offline   Reply With Quote
Old 05-06-2024, 04:40 PM   #13
GB SISSON
GB SISSON's Avatar
And those aren't headers, they are water cooled mainfolds, jacketed so after the cooling water is pumped through the block it cools the exhaust on it's way to the transom. I bet a V8 piped like that would sound great.
