Old 05-03-2024, 10:55 PM   #1
Owlseye
Default Holley or Stromberg carb.
Has anyone used the aftermarket carburetor that replaces the Ford 2 barrel on a 52 F1,2,3 ? When I got my truck it had a Stromberg on it. I have tried several different carburetors of the FORD type after rebuilding them with no luck. I need a carb that works. I want my yard art to move. Thanks.
Owlseye is offline   Reply With Quote
Old 05-04-2024, 06:20 AM   #2
nickthebandit
Default Re: Holley or Stromberg carb.
Contact Charlie NY, formerly here on the Ford barn. 716-662-9159. He is the man for
Ford / Holley carburetor re-building.
nickthebandit is offline   Reply With Quote
Old 05-04-2024, 09:52 AM   #3
Planojc
Planojc's Avatar
X2 on Charlie.
Planojc is offline   Reply With Quote
Old 05-04-2024, 10:27 AM   #4
JayChicago
JayChicago's Avatar
It won't even move? Maybe your problem is something other than the carburetor?
JayChicago is offline   Reply With Quote
Old 05-04-2024, 10:44 AM   #5
Ol' Ron
Ol' Ron's Avatar
You need a Load a matic distributor for that engine, which needs a special carb/ Works great when setup right?????
Gamps
Old 05-04-2024, 01:52 PM   #6
1952henry
1952henry's Avatar
Make sure the 94 has the vacuum port on back for the Load o Matic. Then, make sure the throttle shaft isn’t sloppy in the bore. Also , make sure it has been cleaned, cleaned, cleaned, and that mating surfaces are flat. Last but not least, get a quality kit from Daytona, or Cowboy John ( I think he sells kits). It is a simple carb, not rocket surgery.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
