Old 05-02-2024, 09:48 PM   #1
Dtolson9
Default Pressure plate adjustment
Hello. I’m having a hard time understanding where the 5/8 or 11/16 measurement comes from. Is my pressure plate way out of adjustment? It’s a fresh rebuild
Dtolson9 is offline   Reply With Quote
Old 05-02-2024, 09:49 PM   #2
Dtolson9
Default Re: Pressure plate adjustment
Here’s a picture
Old 05-03-2024, 06:15 AM   #3
jack wingard
Was the flywheel cut? If so the pressure plate mount surface needs to be cut also. The red book gives the correct measurement height between the two surfaces.
jack wingard is offline   Reply With Quote
