Old 04-29-2024, 04:50 PM   #1
spdway1
spdway1's Avatar
Default Does it matter - Tie Rod Direction
Does it matter what side the tie rod (Threads) goes?
I hope I am clear in explaining this:
I marked my tie rod on the driver's side to replace it on the driver's side, When I went to put my new tie rod ends on (Left and right thread), the grease fittings faced forward, the directions say to have them facing the rear, so now my tie rod has to be flipped to the other side.
The old tie rod ends I am replacing have the grease fitting on the opposite side as the bolt clamp side. The new Tawain ones have the grease fitting and the bolt casting on the same side.
Thanks for your help.
spdway1 is offline   Reply With Quote
Old 04-29-2024, 05:25 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Does it matter - Tie Rod Direction
Attached article may help.
http://www.santaanitaas.org/wp-conte...v-Dec-2013.pdf
Tom Endy
Tom Endy is offline   Reply With Quote
Old 04-29-2024, 05:58 PM   #3
nkaminar
nkaminar's Avatar
What was wrong with the old ends? Can't the pads just be replaced?
Unless you are having the car judged, what is wrong with the grease fittings being in front, or what is wrong with turning the rod end for end and having the clamping bolts and grease fitting in the back.
One other option is to tap a 1/8 pipe tread in the rear, making sure to not go too deep so that the grease fitting won't protrude into the inside. And then putting a pipe plug in the other location.
Another option: If the ends are unusable, you could look around for ones that have the grease fitting in the rear.
Normally the right hand thread is on the right side (starboard side) of the car.
Old 05-13-2024, 02:49 PM   #4
Heimer308
Probably an issue with accessibility with a grease gun, maybe towards the front the steering knuckles or axle get in the way.
Heimer308 is offline   Reply With Quote
