Old 04-26-2024, 06:01 PM   #1
rawlir
Default 47 1/2 ton pickup vs Tonner pickup steering column
Would anyone know if there is a difference in steering columns between these 2 models? Does the columns make any difference if 2spoke or 3spoke steering wheels? Steering shafts different?
rawlir is offline   Reply With Quote
Old 04-26-2024, 09:27 PM   #2
GB SISSON
GB SISSON's Avatar
Default Re: 47 1/2 ton pickup vs Tonner pickup steering column
I cannot recall any differences between the two, but then again I wasn't looking for any. It seems I have mixed steering wheels from 2 spoke to 4. Never tried a 3. So my answer is rather vague. If you want me to measure anything I could do that tomorrow. I have only had one half ton and that's the woodie so I have something to compare with my tonners.
Old 04-27-2024, 06:05 AM   #3
Dak Rat
The 1 ton steering shaft is bigger but necks down to take the same size wheel hub.
Dak Rat is offline   Reply With Quote
Old 04-27-2024, 10:42 AM   #4
Bob C
The Parts Book shows 21C-3503-A Gear assy (steering) less wheel
and arm-LHD (commercial 1942-47) (122" Truck 1940-47)
Old 04-27-2024, 02:51 PM   #5
GB SISSON
GB SISSON's Avatar
'Commercial' being the 1/2 ton, 122" being the tonner and if it's got a 131" or longer it's called a 'Truck' in Ford lingo and is a 1 1/2 or 2 ton.
Old 04-28-2024, 09:48 AM   #6
rawlir
Bob C,
Are you saying the parts book shows 1/2 ton & Tonner parts from steering box up are the same?
Thanks all for responding!!
Rick
Old 04-28-2024, 09:57 AM   #7
Bob C
Originally Posted by rawlir View Post
Bob C,
Rick
That's what I get from the parts book.
Old 04-29-2024, 08:22 AM   #8
GB SISSON
GB SISSON's Avatar
The steering box itself seems to be the same. I have swapped them from one to the other with no alterations.
Old 04-29-2024, 10:28 AM   #9
Model51
Model51's Avatar
Here's a clip of this section of the Ford "Green" Parts book. The image is small but legible if enlarged.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 04-29-2024, 11:15 AM   #10
petehoovie
petehoovie's Avatar
Old 04-29-2024, 11:22 AM   #11
GB SISSON
GB SISSON's Avatar
Good detective work Mr. 51. Everyone should have a copy of 'the Good Book' in their automotive library.
