Old 04-14-2024, 06:44 PM   #1
jtminor
Default Frame vin
I recently purchased a 1951 F1, I'm having difficulty reading the vin on the frame, I see it but parts of it are very hard to read, I know its correct because the part I can read matchs the glove box plate,
The title is wrong, I'm in the process of getting that corrected
Any help to make it easier to read, I've been using a steel brush.....
jtminor is offline   Reply With Quote
Old 04-14-2024, 06:57 PM   #2
hotcoupe
hotcoupe's Avatar
Default Re: Frame vin
Hello, try using a thin piece of paper and a pencil laid nearly flat and you should be able to highlight the characters.
Tom
hotcoupe is offline   Reply With Quote
Old 04-14-2024, 07:10 PM   #3
jtminor
Thanks ..... I'll give that a try....
Old 04-14-2024, 10:01 PM   #4
ford38v8
ford38v8's Avatar
The use of a wire brush was perhaps the worst choice you could have made to reveal the serial number. You’re not dealing with tool steel, iron is soft and vulnerable to all abrasives.
Alan
Old 04-14-2024, 10:12 PM   #5
19Fordy
19Fordy's Avatar
Read this VIN number revival info:
https://www.jalopyjournal.com/forum/...learer.621440/
Old 04-14-2024, 10:26 PM   #6
Newc
Newc's Avatar
I use white chaulk, then wipe off frame. Chaulk stays in numbers-had to teach the DMV this trick. Newc
Old 04-15-2024, 02:37 AM   #7
Mart
Mart's Avatar
Sometimes useful to hold a light at a very low angle to cast a shadow across the digits. Also use the camera in your phone to video the area from all angles and use macro mode. Then watch it on a computer screen to identify the digits. Mart.
