Old 03-31-2024, 03:17 AM   #1
3W Hank
Default Waterpumps with smooth pulleys
Somwhere I seen as I thought was 59BA single pulley pumps with steel instead of cast iron.
-What car came this pumps from ?
Another question, in that era to 1950 was it only one type of belt or had they wider and narrow ?
Read Drake has wider or narrow.
Maybe the narrow is a ’modern’ V-belt type.
-I ask since I has a clearance issue but my crank pulley is std and so generator pulley.
3W Hank is offline   Reply With Quote
Old 03-31-2024, 09:50 AM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Waterpumps with smooth pulleys
Hank
Rebuilders may have used steel pulleys.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-31-2024, 10:17 AM   #3
alchemy
alchemy's Avatar
Don’t confuse the 59A stuff with the 8BA stuff (you say “up to 50”). Big changes in 1949, and more variety of pulley, castings, and belts.
alchemy is offline   Reply With Quote
Old 03-31-2024, 11:00 AM   #4
Tim Ayers
'48 in Trucks
Tim Ayers is online now   Reply With Quote
Old 03-31-2024, 05:40 PM   #5
3W Hank
So the truck 48 had the slimmer steel 1 groove ( wide ? ) pulleys.
I try to serach but could not find anything but the pumps I saw is not far away.
He said they was rare but consider nice for hotrods.
If I bought over e-bay, Hamb or here what to look after to find them.
I guess when we talk 48 its wider ( 5/8” or ? )
Old 03-31-2024, 06:03 PM   #6
19Fordy
19Fordy's Avatar
Wide belt pulleys were also on 1949-50 Mercurys and 1948-50 Ford pick ups. Look here:
https://www.bing.com/search?q=1950+f...ANAB01&PC=HCTS
Old 04-01-2024, 03:40 PM   #7
V8guy
I have a pair of 37 to 48 Ford script pumps with steel pulleys appear to be original.
V8guy is offline   Reply With Quote
Old 04-01-2024, 05:04 PM   #8
Kube
Kube's Avatar
They may appear to be but they are not. Sometime in the past, those pulleys were replaced. Ford script? Not until 1945 as I recall.
Old 04-02-2024, 01:23 PM   #9
3W Hank
Kube,
So what you mean in this ( if steel ) pulleys its not Ford std, do did I get it correct or was they out 45 ?
One said truck 47.
Old 04-02-2024, 02:19 PM   #10
Tim Ayers
The "extended" 8RT truck style type pump came up with the '48 F1 series truck. They got the 8BA/8RT in truck speak motors before the cars did in '49.
I believe all trucks were wide belt drives.
Old 04-02-2024, 04:48 PM   #11
Kube
Kube's Avatar
Originally Posted by 3W Hank View Post
Kube,
One said truck 47.
Hank, Ford utilized cast pulleys at least through '48. I have no clue what happened after that.
The Ford script pumps didn't happen until 1947. My (initial) memory was incorrect in recalling '45. I had to check my research notes.
Old 04-02-2024, 04:54 PM   #12
Ronnieroadster
Ronnieroadster's Avatar
Tim your correct all Ford trucks were wide belt.
To my knowledge and so far I have never seen any tin or steel wide belt pulleys from Ford for this application.
Hank if I was doing this I would work with correct parts to accomplish this task. Trying to use the latter magnet with early parts is not very traditional or cool .
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
