03-29-2024, 10:05 PM | #1 |
Main Harness
Any suggestions on the best wiring harness with/without turn signals and with/without cowl lights for the novice? For a 31 Coupe. Thanks.
03-30-2024, 04:54 AM | #2 |
Re: Main Harness
Last one I used, 1 year ago, was from Snyders and there were no issues
04-01-2024, 02:17 PM | #3 |
Re: Main Harness
Just read on another thread here that a guy said Bratton's wiring harness is better because all the ends are soldered. I'd check out both companies.
04-01-2024, 03:47 PM | #4 |
Re: Main Harness
Tyree Harris is the man. He will make whatever you want. Quality work.
04-02-2024, 11:36 AM | #5 |
Re: Main Harness
The best quality harnesses I have seen come from Rhode Island Wire but most of them likely come from Bauer Electronics. If sources make up their own then the wire & possibly terminals likely comes from those and a few other sources. A lot of the terminal ends are crimped and soldered to prevent warranty problems. The light switch round terminal block is another item to check and be sure it is one of the good ones. Some are too thick and some have ident issues where the rotating part of the switch rides over the cupped terminals of the block.
04-02-2024, 12:13 PM | #6 |
Re: Main Harness
