#1 |
I know somebody out there has an original spare tire with a lock on it !!
If it's at all possible I could use a picture of it removed from the wheel or if there's a publication with a diagram of one.I'd like to save this one and I don't whant to drill it out.I have a lock smith working on it now but more help would be greatly appreciated..THANKS FORD BARN..... |
#2 |
I could do that. From what perspective would you like a picture?
#3 |
James
Thank you for the help!! A picture of the lock off the spare would help to see how it's made,I really don't want to distroy it.E-mail me if you can and I know with your help I'll be able to save it... Glenn |
#4 |
Will this help?
#5 |
Don
That's the one !!! I'm guessing the two latches are not going in when the key is turned.I'll show this to my locksmith to see if he has a trick to make it work.Thanks a TON !!!! Glenn |
#6 |
#7 |
I just sent pictures to Glenn, which collectively illustrate the parts shown by Don as a working assembly. After inserting the key, I push inward on the assembly while turning to release the tension on mechanism so that the tabs will retract. Essentially, the locking mechanism is under some tension, and this needs to be "countered" by pushing it inward to get the lock to release. Of course, lots of penetrating oil is helpful if the mechanism is oxidized.
#8 |
Mike, There is a set screw on the side of the larger mechanism with the levers. If you remove the set screw, the lock cylinder should come out.
#9 |
What a home run you all made my day !!!
THANKS GLENN |
#10 |
#11 |
In case you need it....I got help with the same situation from a guy in Missouri who has the Hurd key stock for cutting vintage keys etc. let me know .....tnx D.B.
#12 |
dbrock.....Thanks I'll keep in mind !!!!
