03-21-2024, 10:45 PM | #1 |
what is this?
what is this? found this in the box of some model A parts i picked up.
03-22-2024, 01:41 AM | #2 |
Re: what is this? mag drive?
yes it is, but that mounting plate for the mag is way too thin!
03-22-2024, 07:39 PM | #3 |
The gearing should be 1:1 for a mag or distributor and that gear looks smaller. It might be better suited for a governor of sorts or driving something else.
03-22-2024, 10:05 PM | #4 |
It is an attempt at a side drive magneto
The gear is properly sized for a mag with 2:1 gear reduction or a governor Most aircraft mags are 2:1 or crank speed. J
As Carroll Smith wrote; All Failures are Human in Origin. |
03-23-2024, 11:42 AM | #5 |
All the Lycomings and Continentals I've ever worked on had cam driven mags. They use an idler on one to keep direction of rotation the same. Drive off the cam is 1:1 and the cam runs at half of crank speed. Radial engines have their own way of magneto & distributor function but all of them have to work for 4-stroke operation.
03-23-2024, 01:07 PM | #6 |
