02-27-2024, 05:42 PM | #1 |
BB truck and big truck wheel studs
I was working on the brakes of my '33 BB and was disappointed to find left hand studs on both front drums. I pressed the left hand studs out and pressed out RH studs out of the '34 front axle I had only to find the '34 studs about .005 smaller and won't stay in the drum!
The studs are 1" 3/4 and somewhere around .885 +or- .003 on the press fit shoulder for the '33. I haven't been able to locate any. I might have to make them from bar stock on the lathe but I'd rather not. For now, I guess I'm going to put the lefties back on. Any ideas on where I can get some RH studs? These are not the same as AA truck. |
02-27-2024, 07:20 PM | #2 |
Re: BB truck and big truck wheel studs
02-27-2024, 07:42 PM | #3 |
Thanks! What are using for a parts book that covers the big trucks?
02-27-2024, 07:47 PM | #4 |
Ford and other truck makers installed left-hand threads on purpose. It's probably unlikely right hand threads in place of the left hand originals will have the nuts work free, but why not keep it original?
MACs used to sell the left and right hand nuts and studs for the front and dual rear (4 different studs and 6 different nut sizes). It's been a while snice I purchased any so I'm not sure who is supplying them.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
02-27-2024, 07:56 PM | #5 |
I have plenty of truck nuts in all 6 sizes if you need any. Also there are some studs on ebay. See if this is what you need:
https://www.ebay.com/itm/12424091593...7QJZ0faSLLEv3w
02-27-2024, 08:12 PM | #6 |
02-28-2024, 09:55 PM | #7 |
Do you have photos of what you're looking for? I took 2 AA drums off hubs and those had nuts on the inside of the studs. I bellieve that the '34 front drums that I've seen also have the nuts.
Red |
02-28-2024, 10:13 PM | #8 |
There different than AA. Well that's to small
Try the link to Vince's site. https://www.fordgarage.com/pages/wheelstuds.htm Last edited by Bob C; 02-28-2024 at 10:19 PM. |
