02-26-2024, 08:35 PM | #1 |
Looking for a machine shop in SW Florida
Hello fellas. Been away for a while. Back at it and found a crack from the valve seat to the cylinder. If anyone can suggest a good machine shop I can go to in southwest Florida I would appreciate it. Thanks ahead of time.
Al Last edited by Jockeyshift41; 03-01-2024 at 07:18 PM. Reason: Typo |
02-27-2024, 08:15 AM | #2 |
Re: Looking for a machine shop
My machinist/rebuilder (who does many flatheads and rare and unusual old car motors) who was doing my 59A found a similar crack, and he refused to work on it any more. He said he wouldn’t warrant it, and he said any repair would at best would have 80% chance of holding. Talked to several other machine shops and flathead people, and I did get some opinions that it could be pinned and resleeved, but nobody said it was going to last with no chance of failure. So I found another motor without cracks.
Good luck. |
02-27-2024, 02:21 PM | #3 |
I had the same experience as Bruce two years ago in the Chicago area. The flathead machinist I was using could not guarantee the repair would hold up. I ended up finding a better block.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
03-01-2024, 02:06 PM | #4 |
VicPiano of Tampa/Orlando (Cigar City Flatheads) might be a good contact. He's apparently not an engine builder as such but probably knows good people to recommend.
Al Hook |
03-01-2024, 05:33 PM | #5 |
Jockeyshift 41,
I would suggest editing the title of your post and change it looking for a machine shop in FL. You'll get the attention of those members who live in FL. |
03-01-2024, 07:04 PM | #6 |
Al |
03-01-2024, 07:12 PM | #7 |
Great suggestion! I should have thought of that . I went to edit and can only edit the content. Probably doing something wrong
Al |
03-01-2024, 07:19 PM | #8 |
Thanks for that! I should have known better 😁
Al |
03-01-2024, 07:36 PM | #9 |
I can understand not wanting to guarantee it but I don’t understand what happens that makes it fail. I just repaired one and pinned it and installed a new valve seat. I pressure tested it full of water with 50 PSI of air supplied and no leaks. I’ve seen my long time machinist repair many of them . Some of them been running more than twenty years. A friend of mine brought me an assembled short block for me to bolt on the heads, etc for his car that came from a well known builder on the west coast. I noticed it had been repaired in a couple of valve seats with pins and it looked like an old repair. That was six years ago and it’s still running fine.
