Old 02-24-2024, 03:33 PM   #1
Steve in Denver
Steve in Denver's Avatar
Default speedometer gear
For a Borg Warner in-driveshaft over drive in a '36 with a 4.11 rear, stock tires, I think I need a 16 tooth plastic gear. I currently have a 20 tooth gear and the speedometer shows 25 when I am going 50. I have had the speedometer cleaned and calibrated.
The 20 tooth gear I have has the number 6150862 on it.
Any idea where I can get a 16 tooth that looks like this? A quick on line search did not turn anything up.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 02-24-2024, 05:33 PM   #2
alanwoodieman
Default Re: speedometer gear
go to a local auto trans rebuilder and ask about one
alanwoodieman is offline   Reply With Quote
Old 02-26-2024, 08:26 PM   #3
rjlester
I think the smallest you can get in that type of gear is a 19 tooth, at least that was the smallest I could find online. Here is an example:
https://www.blueovalclassics.ca/driv...-teeth-1955-56
rjlester is offline   Reply With Quote
