02-17-2024, 09:22 AM | #1 |
37 Ford Dash Light Switch
I'm trying to find out if the 37 dash light switch operates the same as the 36.
Is the knob in the pulled out position when the lights are off and pushed in to illuminate the lights? |
02-17-2024, 09:56 AM | #2 |
Re: 37 Ford Dash Light Switch
On my 36, when the dash lights switch is pulled out then the lights are out. terry
02-17-2024, 10:24 AM | #3 |
I think that was changed in 1937. So, if the switch is pulled out then the lights turn on. terry again.
02-17-2024, 10:39 AM | #4 |
Can anyone verify Terry's last statement that in 37 the dash light switch knob is pulled out to illuminate the dash lights?
02-17-2024, 10:50 AM | #5 |
The 35 dash light switch operates opposite than the 36-37. The only differernce between the 36 & 37 is the knob.
02-17-2024, 11:47 AM | #6 |
terry |
02-18-2024, 06:38 AM | #7 |
Thanks for your timely response Terry.
Peter |
02-18-2024, 09:48 AM | #8 |
02-20-2024, 09:56 AM | #9 |
I've always been curious as to why there was a switch to turn the dash lights on/off? If your headlights are on, wouldn't you want your dash lights on as well?
