Old 02-07-2024, 09:42 AM   #1
dbdevkc
Default Intake Manifold gasket material - 1950 V8
We just had to remove the intake manifold and want to replace the gasket. What was on there looks like it was metal(?), but I am finding paper gasket replacements. What should I be looking for?
Thanks.
dbdevkc is offline   Reply With Quote
Old 02-07-2024, 10:58 AM   #2
Shoebox
Shoebox's Avatar
Default Re: Intake Manifold gasket material - 1950 V8
Thanks.
I have always used paper gaskets, lightly greased prior to installation.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 02-07-2024, 12:03 PM   #3
flatjack9
flatjack9's Avatar
I've never seen a metal one.
Old 02-07-2024, 06:14 PM   #4
rotorwrench
rotorwrench's Avatar
Some manufacturers use a sandwich type gasket due to the heat riser area in the block.
Old 02-16-2024, 09:54 AM   #5
dbdevkc
I just started pulling off the old gasket and it is definitely metal. Seems to be a paper-metal-paper sandwich, and it looks pretty old. The indications on the gasket were "MADE-IN-USA", "FEL-PRO", and "8903".
Our replacement is paper only, and that seems to be all that is available. Searching Fel-Pro, I find "MS 8903" and that looks to be paper also.
Old 02-16-2024, 10:55 AM   #6
cadillac512
cadillac512's Avatar
I do not like the paper only gaskets. Some are two-ply and separate at the rear and leak oil. Michael at Third Gen has the metal sandwich gasket and it's far superior.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
