Old 12-21-2023, 05:44 AM   #1
ford nut
ford nut's Avatar
Default 1936 grill lower air scoop picture.
i'm looking for a picture of this sheet metal air scoop that bolts up to the bottom of the radiator on one end, and the lower grill on the other. my project didn't have one and i've never seen one. is it something i can make? any photos would help, thanks.
ford nut is offline   Reply With Quote
Old 12-21-2023, 10:15 AM   #2
terry
Default Re: 1936 grill lower air scoop picture.
If you have the1935-36 Ford book, there is a picture of it on p70. It is part #68-16554.
I have been told this was often not put back on by mechanics because it was such a pain
in the butt to get back on after they completed work. If you have to work on the ditributer or other parts in that area, this has to be taken off. It is called a radiator shield, used to direct air towards the radiator. I bought one and can attest that it was a real pain to get it on. Maybe it was not made quite to specs because the holes just wouldn't line up no matter what I did. terry
terry is offline   Reply With Quote
Old 12-21-2023, 10:43 AM   #3
deuce lover
deuce lover's Avatar
Here from the Bible
Check with Southside Obsolete in MN.Fred might have one.
deuce lover is offline   Reply With Quote
Old 12-21-2023, 11:07 AM   #4
ford nut
ford nut's Avatar
i don't have that book. i would like to have though if i could find one. maybe some one here can take a pic of that page. but it sounds like i could wait and come up with something myself. i have a drawing saved that has picture, but it's not much. i'll see if i can find it.
Old 12-21-2023, 11:22 AM   #5
DavidG
DavidG's Avatar
The referenced book is available via the Early Ford V8 Club website (earlyfordv8.org) for $29.95; it's areal bargain.
Old 12-21-2023, 11:51 AM   #6
dean333
dean333's Avatar
Send a message via Yahoo to dean333
C’mon guys, it’s not THAT hard to install! Use a long punch to align the holes on one end, the metal is easy to pry into position. Ten minutes tops.
Tim Carlig
dean333 is offline   Reply With Quote
Old 12-21-2023, 04:26 PM   #7
terry
Tim, are you talking about an origina scoop or one that may have come from China?
Old 12-21-2023, 05:07 PM   #8
mercman from oz
mercman from oz's Avatar
1936 Ford lower grille support.
ford nut is this the part that you are looking for a picture of?
Old 12-21-2023, 05:52 PM   #9
ford nut
ford nut's Avatar
no, i have that one. thanks. it's #16554 from the drawing.
Old 12-21-2023, 05:53 PM   #10
ford nut
ford nut's Avatar
china making this part?? no thank you.
Old 12-21-2023, 09:10 PM   #11
Gary Tosel
Gary Tosel's Avatar
If you can find an original lower air scoop, it will have the horizontal grooves raised across the scoop. Early reproduction parts had these grooves recessed rather than raised. Only a subtle difference, however I believe they made it that way to avoid copywrite costs that Ford requires to allow you to represent the part as the same as from Ford. Bob Drake has to pay these costs when they represent the part as the same as Ford original and show the Ford oval trademark.
Gary Tosel is offline   Reply With Quote
Old 12-21-2023, 09:16 PM   #12
mercman from oz
Radiator & Grille Assembly for 1936 Ford Passenger Car
Old 12-21-2023, 09:48 PM   #13
ford nut
ford nut's Avatar
gary, thanks for the info.
mercman, thanks for the enlargement.
i'm going to call "the early store" here in so-cal and see what they might have. i still would like to make it though. . .i just need to see one.
Old 12-22-2023, 12:01 AM   #14
Randy in ca
Randy in ca's Avatar
This one is on eBay:
https://www.ebay.com/itm/166403028770
Randy in ca is offline   Reply With Quote
Old 12-22-2023, 12:21 AM   #15
ford nut
ford nut's Avatar
hey thanks! just what i was looking for! pretty nutty price, but there it is. doesn't look like the illustration too much, this really helps me. thank you Randy in ca.
Old 12-22-2023, 11:31 AM   #16
dean333
dean333's Avatar
Terry, I’m talking original.
Tim Carlig
Old 12-22-2023, 12:20 PM   #17
Karl Wescott
Karl Wescott's Avatar
To my knowledge repops have never been made in China. The only ones I know of are made in Texas.
Karl Wescott is offline   Reply With Quote
Old 12-22-2023, 01:13 PM   #18
ford38v8
ford38v8's Avatar
If you want to make your own, consider the required function as more important than what it looks like. It’s not there for looks, without it you’re likely to overheat.
Alan
Old 12-22-2023, 01:34 PM   #19
terry
The odd thing for me was that i went quite a few years without having the part on and as long as I wasn't standing and waiting in a long line my 36 wouldn't overheat. Is there someone that still makes a circular fan shroud for the older v8s to remedy this situation?
Old 12-22-2023, 09:23 PM   #20
ford nut
ford nut's Avatar
of course. . .
