Old 12-15-2023, 12:31 PM   #1
jdjj
Default flathead heater shut off valve
Any one know where to get heater shut off valve for 1953 pickup flathead. This the one that screws in head. I can find the ones with straight nozzle end for hose but mine angles up to clear head when screwing in.
jdjj is offline   Reply With Quote
Old 12-15-2023, 12:41 PM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: flathead heater shut off valve
Check with Third Gen Automotive or Southside Obsolete.
Seth Swoboda is offline   Reply With Quote
Old 12-15-2023, 02:21 PM   #3
HDowse
HDowse's Avatar
There’s one in the V8 swap section.
https://www.fordbarn.com/forum/showthread.php?t=331880
HDowse is offline   Reply With Quote
Old 12-15-2023, 02:48 PM   #4
Newc
Newc's Avatar
I rebuilt mine by buying a modern one from NAPA , and then using the valve assembly in the cleaned up Ford original. Valves were the same. Newc
Old 12-15-2023, 03:37 PM   #5
Seth Swoboda
I actually thought about this but wasn't sure if it would work without having tried it.
Thanks
Old 12-22-2023, 11:25 AM   #6
jdjj
thanks did find one on line
