12-13-2023, 07:42 PM | #1 |
problems instaling rear brake drum
I'm trying to install my right rear brake drum on my '30 coupe. The whole setup was just rebuilt by Snyder's. I had difficulty getting the drum on over the shoes, then remembered I'd had to pull on the service brake lever to line up the clevis and pin. I removed the clevis pin, the lever retracted, and the drum went on. When i tightened the axle nut (not torqued), the drum went on further, but now it won't turn. I thought turning the adjusting wedge counterclockwise might give me more room, but I couldn't get it to turn. It went a couple of clicks clockwise, but wouldn't turn the other way.
What am I doing wrong? |
12-13-2023, 07:51 PM | #2 |
Re: problems instaling rear brake drum
Did you arch the shoes to the drums? the shoes need to be matched to the drum to fit, if it went on halfway over the shoes with little difficulty but started hanging up once you put the drum all the way on that's either the emergency brake band dragging on the drum or you have the drum rubbing on the backing plate. you can easily fix drums hitting the backing plate by installing a shim on the axle. the e-brake band can be fixed by just taking the band off and honing it down with a grinder or sander.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
12-13-2023, 11:09 PM | #3 |
So, you have a new drum on your old hub?? Or do you have both a new drum and a new hub?? If you have a new hub, the axle shim may be required to keep the drum from rubbing/binding on the backing plate. By the way, do you have a new backing plate??
Just what do you mean by "the whole set up was just rebuilt". |
12-14-2023, 02:01 AM | #4 |
Snyder's rebuilt my backing plate, relined service brake shoes and emergency brake band. They installed my hub on a new brake drum and arched the shoes to the drum.
12-14-2023, 06:20 AM | #5 |
I think that the new drum is hitting your backing plate, and the shims will fix the problem. Worked for me when I had the same problem.
12-14-2023, 08:35 AM | #6 |
12-14-2023, 10:03 AM | #7 |
When installing the hub on the axle make sure both the hub and axle are completely clean and dry, no oil, the same goes for any shim(s) if installed.
12-14-2023, 01:27 PM | #8 |
Thanks for your help.
I disconnected the rod to the emergency brake lever, and that allowed me to slide the drum on. It fits fine and turns easily. But I still can't get the adjusting wedge to turn. Suggestions? |
12-14-2023, 01:56 PM | #9 |
Did you install the wedge or did Snyders?? Did you try the wedge before you installed the shoes? Did you try to adjust the shoes before you installed the drum?? Do you know if the wedge is all the way out already??
12-14-2023, 02:11 PM | #10 |
Sounds like the wedge is turned all the way "out" (counterclockwise) and jammed against the stop. If you can turn the drum easily then this is consistent. You could call Snyder's and ask them if that is how they normally ship their rebuilt backing plates (it seems logical to me that is the way they would leave the rebuilder). Or you could assume that is the case and now proceed to adjust the brakes properly by rotating the wedge inwards (clockwise). Take a picture showing how much thread is showing outside the backing plate?
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
12-15-2023, 12:05 PM | #11 |
You're right about the adjusting wedge being all the way out. I spoke to Snyder's and they agreed. I'll wait until everything is back together and then tighten things up if need be. Thanks for your help
12-15-2023, 12:21 PM | #12 |
Sometimes helps to re-tap the backing plate for the adjusting wedge. Snyders may have done that.
12-15-2023, 04:22 PM | #13 |
Hello, the brake adjuster is a cone shaped affair with notches machined into it , when you turn it , the brake shoe will be on the non machine area and snug up then will loosen up as it falls into the slotted area ,as you turn it inward, once you start working on it you see what I mean.
12-15-2023, 06:54 PM | #14 | |
Model A Ford How to Stop on a Dime To do the rear brakes does require a specific sequence lest the cam falls out on ya. There is also a tool that makes this even easier. I got mine at Mike's affordable, as I remember. It looks like a pistol grip and attaches to the end of the shoe to give leverage.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
