#1 |
I recently purchased a 1947 Mercury 114 with 3 on the tree, V8 flathead. When cruising and not much torque on the engine it will drop out of 2nd and into neutral. This especially happens when depressing the clutch to slow down. My mechanic said it was probably just wear but it is annoying and would like to fix it. Any help appreciated.
#2 |
>>>it is annoying and would like to fix it.>>>
AFAIK, there are only 2 ways to fix it. The easy way. And the hard way.
#3 |
Maybe Mac VP will weigh in here. That issue could be caused by a shifting linkage that needs adjusted, worn synchronizer rings, worn shift housing parts like the balls, other issues. The rings are brass and prone to wear. I think there is a spec on them to check.
JB |
#4 |
from under the car remove the second/high gear shift linkage on the trans. shift arms closest to front of the car, shift the linkage to second and see if it feels tight or sloppy next, have some one put the trans in second gear on column and hold it there while you see if the linkage will now slip over the arm on trans, if it will not go chances are the linkage is out of adjustment, Ford trans of this era do not have very good thrust washers on the cluster gear and if this clearance is too much it will pop out of second gear
#5 |
Thank You. We will give a try
#6 |
#7 |
My 114 does the same thing. All 40's up, column shifters. Newc
#8 |
Does anyone know how much this would roughly cost? Sounds like the rebuild will be mostly labor and I am not a mechanic.
#9 |
Before I took out the transmission, I would check your linkage. On the column shift there are numerous places for slop to occur. The shifter on the bottom of the steering column has numerous wear parts, the shifter grommets for the rods, and the shift lever studs on the trans. All that adds up, and could be keeping you from seating the shift balls completely in the indentations on the inside shifter plate. I would put it in 2nd, then remove the linkage and make sure the lever is really engaging 100% in 2nd. If not, those are simpler repairs. If your linkage is good, then I would talk to Mac and get his book. I am no mechanic either, but have rebuilt several 3 speeds and they work awesome. It’s not hard with good parts and a good direction.
JB |
#10 |
Check your linkages first. If it just needs thrust washers, blocker rings and bearings....a few hundred bucks. But I rebuild my own. It's really pretty simple.
#11 |
Thank you for your input!
#12 |
I would also recommend getting Mac Van Pelts book , shows you how to disassemble , reassemble , determine what parts are worn and need to be replaced.
You may want to talk to members of the Vancouver Fraser Valley RG#120 Early V8 Ford Club as they are in your area. Look for a spare transmission to familiarize your self with and rebuild it. They should be available in your area as lots of these vehicles do get modified Regards, Flathead47 |
