11-15-2023, 03:13 PM | #1 |
FH pressure test
Anyone have a pressure test kit that they would be willing to sell?
11-15-2023, 03:30 PM | #2 |
Re: FH pressure test
Which flathead?
11-15-2023, 09:32 PM | #3 |
I haven’t found the adapter the fits on the radiator neck for my 34, 36 or 37 in ANY pressure test kit.
Tim Carlig |
11-15-2023, 09:41 PM | #4 |
I think most people referring to a pressure test kit for a flathead V8 are wanting to perform the test on a bare block. This involves some specialized test plates. Speedway has carried these kits in the past, but they have been 'out of stock' for a number of years. You can follow my attempts on a thread here called 'Testing Blocks at Home'. Now that it's winter I plan to get back and finish up my test kit.
11-15-2023, 09:56 PM | #5 |
Kind of off topic but still a pressure test. 1962, while hauling 2 tons of hay across the Mojave Desert in my Dad's 1/2 ton '50 International pickup the upper radiator tank developed a pin hole leak. No tools or supplies so I stopped & cut a mesquite branch, whittled it to a point & stuck it in the hole. Made it 35 miles up the mountain to Big Bear Lake with no problem. I guess it passed the test! Local radiator shop fixed it for $5.
11-16-2023, 08:24 AM | #6 |
Pressure testing which??? Bare block, IF so, 21 stud, 59A or 8BA -OR- Cooling system |
11-16-2023, 12:06 PM | #7 |
I just had a 21 stud "pressure testing" plate made to locate a combustion leak into my cooling system. I have Speedways 24 stud plate, but needed the 21 stud. Mine is 1/2" thick, with a 1/4" rubber gasket. I just used it, and discovered a pin hole in the combustion chamber, barely visible!! I can have these made for $250. Let me know!!
11-16-2023, 12:10 PM | #8 | |
11-16-2023, 12:11 PM | #9 |
Doug
Fortunately one of my good customers has a water jet cutter, he had his guy cut me a set of 21 stud plates and neoprene gaskets for me for a 12 pack of beer. I should have had a set cut for the 59 series but didn't. Hopefully I can get some done at some point!!! |
11-16-2023, 12:12 PM | #10 | |
11-17-2023, 07:13 PM | #11 |
Nice ! But I see that sawzall in the back ....
11-18-2023, 09:02 AM | #12 |
Lol, IF you are implying I cut them myself with a sawzall, look close at my cut lines, IF I cut that clean with a sawzall I could make millions cutting for people, especially the 1/8 neoprene gaskets I cut with it!! NOT to mention the bolt circles
Actually the sawzall is there as I took this picture at work, the guys in my warehouse were using it to cut up pallets and broke the blade guard and brought it up to me so I could get it fixed!!! Truth be known!! |
