Old 11-11-2023, 01:45 PM   #1
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Default Ford poured rear bearing
Does anyone have pictures, or drawings of the specs of the rear main, in the block. Specifically, was the forward parting line open into the engine, or was it closed like the other bearings? I’ve seen pouring both ways. TIA
Old 11-11-2023, 03:00 PM   #2
SAJ
SAJ's Avatar
Default Re: Ford poured rear bearing
Chuck, I cannot recall the pics, but I think an open groove will spill the pressure from the dynamic hydraulic wedge that is necessary for separation of the surfaces.
Thinking about that I recall finding an open rear main groove in our Tudor. I obtained some babbitt puddling stick and used a soldering iron to block and then hand-scrape the bearing back to the picture Herman Khonke (RIP) posted years ago.
Vince Falter has good pics on his Web site too.
Sa
SAJ in NZ
SAJ is offline   Reply With Quote
Old 11-11-2023, 05:15 PM   #3
Gene F
Gene F's Avatar
Also, since it has that tube in the back, I'd think that the area should be closed.
Gene F is offline   Reply With Quote
Old 11-11-2023, 05:38 PM   #4
Modelacoupe3
Modelacoupe3's Avatar
[QUOTE][/QUOTE
See attached photos . The rear bearing pictured was poured by Ford in 1930. The engine / car had 53,000 original miles on this bearing .
Modelacoupe3 is offline   Reply With Quote
Old 11-12-2023, 09:08 AM   #5
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
On my engine prints, the oil groove basically travels from one hole in the block for locking the casting to the opposite side hole on the opposite end of the journal. It does not end at the end of the bearing, but stops approximately 3/8" from the end. The print calls for the depth of the oil groove to be 1/32" - 3/64", and the width to be 3/32".
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-12-2023, 10:00 AM   #6
hazelhoff
hazelhoff's Avatar
Oil grooves really are a NO GO area. If you can, avoid applying them ! 1930-ties engineering mistake !
You don’t own a Model A ... it owns you !
hazelhoff is offline   Reply With Quote
Old 11-12-2023, 10:46 AM   #7
rotorwrench
rotorwrench's Avatar
They were not intended to exit the bearing surface. They always need to fall short of the edges or unnecessary leak down will result. They best lubricate the bearing if they are confined to the bearing surface only. There is enough leakage out the ends without adding more easy pathways.
Old 11-12-2023, 11:29 AM   #8
katy
katy's Avatar
What exactly are you calling "the forward parting line"?
Old 11-12-2023, 02:27 PM   #9
Chuck Sea/Tac
The parting line is where the cap and block bearings mate up. Forward is towards the front of engine. See modelAcoupe3’s pictures. Thanks everyone!
Old 11-12-2023, 03:02 PM   #10
ursus
On the Model B rear main, Ford made the oil grooves in the form of an "X" and extended the grooves to the forward end and down the thrust face, thus creating an open pathway to the sump. I wonder if this was because the bearing was now pressurized, albeit at a low pressure.
I have only seen this on original engines produced by Ford. Subsequently rebuilt engines had bearing grooves cut in the manner of the Model A bearings. Some rebuilders even did away with the grooves altogether but retained the wells at the parting line.
ursus is offline   Reply With Quote
Old 11-12-2023, 06:15 PM   #11
BRENT in 10-uh-C
Nonsense! The oil grooves were solely intended to be a passage way for the oil to be transferred from the Oil Pipe to the Oil Well located at the parting lines where the Cap meets the Block. This ensured the width of the crankshaft journal pin was lubricated enough where the micro-scratches in the pin's finish were to carry the layer of oil onto the bearing surface.
The biggest issue that causes bearing failures is people (-i.e.: rebuilders) have trouble redoing something just like Ford engineers specified. The irony is the Ford engineer's design generally lasted for 50,000+ miles of service yet when the rebuilders do it their way, premature failures happen almost immediately. Leave that groove out and see what the longevity is like too.
BRENT in 10-uh-C
