Old 11-07-2023, 10:46 PM   #1
ahshoe
Default Power steering pump question
Wondering if a factory 1961 Galaxie power steering pump (Eaton I believe is the stock 61 one) can be switched with a 1967 ps pump? In other words will a 1967 factory ps pump work with the control valve and other under car ps parts on a 1961 ? Not concerned about the actual bracketry or hoses…but the newer pump working with the 1961 under car parts if it matters it will be on a 390 motor.
ahshoe is offline   Reply With Quote
Old 11-08-2023, 09:21 AM   #2
KULTULZ
KULTULZ's Avatar
Post Re: Power steering pump question
Yes. Can I ask why?
The later pump(s) can be a THOMPSON or SAGINAW, both producing more pressure than the EATON. And then you would have the PS HOSE nightmare.
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL -
KULTULZ is offline   Reply With Quote
Old 05-02-2024, 04:16 PM   #3
Mrwax11
Default Re: Power steering pump question
does the 1967 galaxie 500 have power steering?
Mrwax11 is offline   Reply With Quote
Old 05-03-2024, 02:44 PM   #4
Abe Lugo
if its ram style PS at the bottom on both the pump should be OK to update.
I have had the PS nightmare on another build but found a modern R&P Ford pump that is lower PSI and works- so far
Abe Lugo is offline   Reply With Quote
