Old 11-01-2023, 05:31 PM   #1
Two cool 1929
Default 28-29 30-31 Model afour door sedan's
How can I tell the difference between a 28-29 and 30-31 Model A four-door sedan
Two cool 1929 is offline   Reply With Quote
Old 11-01-2023, 07:33 PM   #2
Gary WA
Gary WA's Avatar
Default Re: 28-29 30-31 Model afour door sedan's
Hub caps small 28-9, 30-31 larger diameter, light bar straight 28-9, 30-31 more curved, Bumpers 28-9 have a flared end, 30-31 straight, Radiator smaller on 28-9, wheel size 30-31 are 19",fenders etc. Headlight shapes 28-9 cone,30-31 rounded more. You could go to some websites and look at some, MAFCA.com. Model A Ford Club etc.
www.whidbeymodelaclub.com
Old 11-01-2023, 11:54 PM   #3
Dave Mellor NJ
He's probably asking about the body.
Dave Mellor NJ is offline   Reply With Quote
Old 11-02-2023, 12:35 AM   #4
Two cool 1929
Yes I'm trying to figure out the difference in the body because I know other four door bodies 28-29 look like a 30-31 I got a four door bodie and wanted to try to find out the year
Old 11-02-2023, 05:38 AM   #5
Scott NY
Scott NY's Avatar
30-31 gas tanks drop in from the top the 28-29 tanks install from underneath
Scott NY is offline   Reply With Quote
Old 11-02-2023, 09:09 AM   #6
The Master Cylinder
The Master Cylinder's Avatar
From the cowl back I believe all Briggs Fordor bodies are the same. Same with Murrey Fordor bodies.
I want to add this is a generalization. Of course the two window and three window fordors are different.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-02-2023, 12:50 PM   #7
Gary WA
Gary WA's Avatar
Pictures would be very helpful?
Old 11-02-2023, 04:56 PM   #8
Gene F
Gene F's Avatar
The two piece splash pans (over running boards) is always a thing I notice.
Gene F is offline   Reply With Quote
Old 11-03-2023, 01:43 AM   #9
Two cool 1929
Here's a few pictures
Old 11-03-2023, 02:45 AM   #10
mercman from oz
mercman from oz's Avatar
Ford Model A Fordor Sedan Body owned by Two cool 1929
Old 11-03-2023, 02:50 AM   #11
mercman from oz
1930 Ford Model A Three-Window Fordor Sedan
Old 11-03-2023, 02:51 AM   #12
Two cool 1929
I'm guessing it's a 30-31
Old 11-03-2023, 02:56 AM   #13
mercman from oz
1928 Ford Model A Fordor Sedan.
From these illustrations, your Sedan cannot be a 1928 or 1929 model.
Old 11-03-2023, 03:39 AM   #14
mercman from oz
1931 Ford Model A Slant Window Fordor Sedan
Old 11-03-2023, 06:59 AM   #15
ryanheacox
ryanheacox's Avatar
Is that a tank or just a panel where the tank would go? 1929 saw the change from the 60 series Fordors to the 155/165 series that carried through 1931. A 60 series from 28-(mid?)29 would be very easy to tell apart, the later bodies would be tougher. All Fordors (except taxi) had a more streamlined, more 30-31 style cowl.
Looks like you have a 165 (standard) Briggs body. I don't know enough about the 29's to say what year it is though. Definitely not a 28.
ryanheacox is offline   Reply With Quote
Old 11-03-2023, 05:50 PM   #16
mercman from oz
1929 Ford Model A Briggs Body Sedan.
Note, the Briggs Body Sedan was only a two window, not three.
Old 11-03-2023, 08:41 PM   #17
w.michael
w.michael's Avatar
You have a 1930 or early 1931 Briggs body Fordor. In 1931, there were two different fire walls. The area where the gas line attaches at the firewall under the hood is referred to as either "flat" or "teardrop." Firewalls were flat for all of 1930 and until approximately the end of March of 1931. After approximately March of 1931, firewalls were teardrop. Your firewall is flat, meaning your body is from 1930 or early 1931. Based on the shape of the top of the side windows, your body is a Briggs body, not a Murray body. A picture of the gas tank inside the car where the instrument cluster attaches would further narrow it down as to either first half of 1930, or second half of 1930 through early 1931.
The illustration in Post # 13 above is an artist's drawing, and is not accurate. I don't think any Fordor was ever produced with that gas tank/cowl configuration, unless it was something built in Canada or built for export. Don't go by that drawing.
There are approximately forty 'leven different Fordor models. Some of those different models are just trim level changes of the same body shell, and some are different body shells, some with three windows on each side, and some with two windows on each side. I don't know which model yours is. It does not appear to have holes in the cowl for cowl lights, which would mean it is not a "town sedan." (Maybe the holes are there, and I just can't see them in the picture.) Don't be tempted to add cowl lights if it doesn't have the holes. The "standard" models are more rarely restored than the "deluxe" town sedan models. And many standard Fordors are converted to town sedans upon restoration. Everyone seems to want maximum bling when they do a restoration, only to learn later that standard cars are pretty neat also, and maybe more rarely seen today.
W. Michael
w.michael is offline   Reply With Quote
Old 11-03-2023, 11:50 PM   #18
Dave Mellor NJ
That car in the drawing has the Taxi cowl
Old 11-04-2023, 12:13 AM   #19
w.michael
w.michael's Avatar
Ah, yes, I forgot the taxi had that cowl/gas tank combination. The taxi was not the same body shell as any other Fordor, I think. Didn't the taxi have larger quarter windows, and maybe wider rear doors?
So make that forty 'leven and one Fordor models.
W. Michael
Old 11-04-2023, 02:27 AM   #20
dave in australia
W. Michael
The Taxi bodies were a bit longer, about 2" from memory.
dave in australia is offline   Reply With Quote
