Old 10-28-2023, 08:47 PM   #1
B-O-B
B-O-B's Avatar
Default flathead starter motor
Can anyone give me the weight of a 34 Ford 221 stud 6 V starter motor. I have tried to use google search, but it is like everything else, giving me 12 volt, model A 4-cylinder, late model you name it.
18-11002 FORD FLATHEAD STARTER 6 VOLT 1934
B-O-B is offline   Reply With Quote
Old 10-28-2023, 09:26 PM   #2
19Fordy
19Fordy's Avatar
Default Re: flathead starter motor
I just went out in the garage and weighed my 1949-53 239cubic in. V8 stock 6 volt starter motor just for you. It weighs 20 pounds.
As I recall that starter is standard design for all of Henry Ford's V-8s.
Old 10-28-2023, 10:21 PM   #3
petehoovie
petehoovie's Avatar
Old 10-28-2023, 11:22 PM   #4
B-O-B
B-O-B's Avatar
Just what I needed thank you very much 19Fordy.
Old 10-29-2023, 04:13 AM   #5
big job
big job's Avatar
Now for a 20# starter I would need a floor jack that why I do not do birthdays LoL
big job is offline   Reply With Quote
Old 10-29-2023, 08:24 AM   #6
jimvette59
jimvette59's Avatar
Is that for shipping purposes ?
jimvette59 is offline   Reply With Quote
Old 10-29-2023, 10:26 AM   #7
19Fordy
19Fordy's Avatar
To make the 20 lb. installation of your starter a lot easier to install take a look at Photo #8 in the first post #1. Installing the little strip of metal to hold the starter end plate in place so starter won't come apart when installing it makes the job much easier. You will be glad you made this modification as it also makes storing the starter easier. And, don't forget the oil pan support bracket.
https://www.fordbarn.com/forum/showt...6v+starter+12v
