Old 10-27-2023, 09:15 PM   #1
qmdv
qmdv's Avatar
Default Oil after break-in
I have been looking at running Valvoline 822347 VR1 Racing Oil, 20W50 after break in. It is listed as conventional oil. I am used to oil listed as detergent and non detergent
Tim
qmdv is offline   Reply With Quote
Old 10-27-2023, 09:42 PM   #2
qmdv
qmdv's Avatar
Default Re: Oil after break-in
So maybe conventional means it is not synthetic
Tim
Old 10-27-2023, 11:57 PM   #3
cadillac512
cadillac512's Avatar
Tim
That's correct. Also,I don't know what detergent level VR1 contains as racing designated oils sometimes differ in that regard.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 10-28-2023, 03:18 AM   #4
69a
VR1 is recommended because it has a high Zinc content which is beneficial for flat tappet engines. There are some on here that say we don't need it on our engines because of the low valve spring pressure. I am no expert. but I am running VR! 20W50 in a rebuilt Flathead. My oil pressure is 80psi even after 20 miles at 180deg. I think 80 is way to high! So I'm thinking 10W40 or 15W40 may be better. If you are running an oil filter (any style) I don't think detergent level will matter.
69a is offline   Reply With Quote
Old 10-28-2023, 07:53 AM   #5
V8 Bob
V8 Bob's Avatar
VR-1 is available in 10W30, and is the best weight for most modified street engines.
V8 Bob is offline   Reply With Quote
Old 10-29-2023, 11:34 AM   #6
deuce_roadster
deuce_roadster's Avatar
It is my understanding that "detergent" and "non detergent" are references that are meaningless in today's world. All modern oils have a chemical substance to keep foreign things in suspension to be trapped by a filter, aka "detergent". If you don't run a filter, just change the oil more often. Those terms harken back to the days of paraffin-based oil which was crap compared to lubricants today. I guess if you like sludge or miss it, the old "non detergent" oil would be your choice if still available.
I do have 1 flathead car out of 5 without an oil filter, A multiple Dearborn recipient, that gets regular oil changes. Every flathead I have was rebuilt, and clean to start with.
If you have an old high mile engine already full of sludge, I would disassemble it and clean it out and put it back together if it had no issues.
My 2 cents.
