Old 10-27-2023, 07:40 PM   #1
8EL
8EL's Avatar
Default Torque Tube Bushing
Hello, I believe that I have the torque tube outer race bushing properly installed, but would like confirmation. The tit at the top must be engaged in the relief hole bored in the tube, as the outer edge of the bushing in flush with the bore. Also, the new replacement cartridge bearing is taller than what was removed. The old bearing with the thrust washer is exactly the same height as the new bearing without the thrust washer. Is the thrust washer to be discarded when using the new replacement bearing?
8EL is offline   Reply With Quote
