Old 10-05-2023, 07:23 PM   #1
SoCalCoupe
SoCalCoupe's Avatar
Default Source of 6V Generator Field Coils
Anyone know of a source for 6V generator field coils for my stock 1941 Ford? I'm pretty sure the decomposition of mine is the source of the loud "shuck, shuck, shuck" noise in my generator. I could see apparent scuffing when I took it apart. It's not the bearing or the bushings.
I've tried C&G Ford Parts, Third Gen, CW Moss, Van Pelt, and MACs. No joy.
Ford tractors have the same part number, think that would work? Hard to tell from the illustration.
https://www.completetractor.com/fiel...ors-262-14000/
SoCalCoupe is offline   Reply With Quote
Old 10-05-2023, 07:45 PM   #2
Zeke3
Zeke3's Avatar
Default Re: Source of 6V Generator Field Coils
Check with Fred at Southside Obsolete, barnfind08 on the Barn.
Zeke3 is offline   Reply With Quote
Old 10-06-2023, 12:17 AM   #3
Newc
Newc's Avatar
Truck n tractor electric lots of OLD stuff Albany, Or 541-928-7451 Terry---Newc
Old 10-06-2023, 05:12 AM   #4
ndnchf
ndnchf's Avatar
I just bought 2 sets off Amazon a couple weeks ago, but they are currently out of stock. Keep an eye on Amazon, they should be restocked soon.
DB Electrical 262-14000 Field Coil Compatible with/Replacement for Ford 01A-10175, 1GA10000, 1NC10000, 21AS10000C, 2GA10000, 5GA10000, 7HA10001B, 81-10175-A, 81A10000D Tractors https://a.co/d/78fwaIu
You may be able to save yours by rewrapping and rewiring yours. I've done this many times.
ndnchf is offline   Reply With Quote
Old 10-06-2023, 05:33 AM   #5
38 coupe
38 coupe's Avatar
Here is a link to a series of short videos made by ndnchf about generator repair: https://www.youtube.com/watch?v=IJc-...Mt1HpMpMhiSOsR
Old 10-06-2023, 07:04 AM   #6
KiWinUS
KiWinUS's Avatar
How many sets do you want? Gobs listed on eBay
Old 10-06-2023, 10:51 AM   #7
petehoovie
petehoovie's Avatar
Old 10-06-2023, 11:24 AM   #8
Model51
Model51's Avatar
Also, be sure the bolt which secures the coils and magnets to the case are installed very tightly. There's very little clearance between the armature and the coils so it's possible the armature can rub on the coils or magnets. ndnchf might cover his installation process using a muffler expander to align everything and snug things up inside the case before tightening the screws using a press and a fixutre he built.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 10-06-2023, 11:02 PM   #9
Seabees
https://www.wilsonautoelectric.com I believe this is where the Model A vendors get them.
Seabees is offline   Reply With Quote
