Old 10-03-2023, 09:09 AM   #1
Shoebox
Shoebox's Avatar
Default Stewart Warner Electric Speedo
Forgive me if this is a bit "off topic" for here but there are some really electrically savvy guys here. So, I have an electric SW speedo in my '32 fed by a GPS module, it has worked well and I don't have to change anything when I change gears in the quick change rear end. Yesterday I get in to go for a Fall drive and right away I see something wrong, the needle is at rest at the high end (see pic) and once underway there is no movement. IF it was just no needle movement I'd check power to GPS module and from it to speedo (will still do this) but that needle pegged as it is has me puzzled. Any thoughts most welcome. Thanks.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 10-03-2023, 09:33 AM   #2
itslow
itslow's Avatar
Default Re: Stewart Warner Electric Speedo
Is the needle still pegged when the GPS module is disconnected from the speedometer?
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 10-03-2023, 09:41 AM   #3
Shoebox
Shoebox's Avatar
Don't know yet, but needle doesn't even twitch when key is turned on/off.
32 Ford roadster
39 Mercury Towncar
Old 10-03-2023, 10:48 AM   #4
petehoovie
petehoovie's Avatar
Old 10-03-2023, 06:17 PM   #5
Shoebox
Shoebox's Avatar
FWIW, I called a SW support line and was on hold for 30 minutes. Later in the day I tried a different number and spoke to a tech guy who wasn't able to really help. So any ideas at all most appreciated. Thanks.
32 Ford roadster
39 Mercury Towncar
Old 10-03-2023, 06:38 PM   #6
Krylon32
I just googled Stewart Warner GPS Speedometer and a page came up with some trouble shooting suggestions.
Krylon32 is offline   Reply With Quote
Old 10-04-2023, 08:05 AM   #7
Shoebox
Shoebox's Avatar
I'm on my way to Google!
32 Ford roadster
39 Mercury Towncar
Old 10-04-2023, 08:23 AM   #8
GB SISSON
GB SISSON's Avatar
Might be a good idea to type the full word for 'speedometer' before you do that. Just sayin....
Old 10-05-2023, 11:14 AM   #9
itslow
itslow's Avatar
Start by disconnecting the GPS module from the speedometer. That will isolate the two and allow you to determine if the issue is in the speedometer or if it's the GPS module.
I'm assuming the GPS is not powered when the key is off, which would lean me toward the speedometer being damaged internally.
Which would then lead me to ask how did it get pegged? Did something break in its needle mechanism, or did the GPS provide an erroneous signal that caused it to max its MPH and subsequently damage the speedometer?
Mike
Wanted:
- ARDUN parts
Old 10-05-2023, 12:23 PM   #10
Tony, NY
I have the same setup. Try hitting the calibrate button on the speedo and see if it moves. Check for power and ground to speedo.
Tony, NY is offline   Reply With Quote
Old 10-06-2023, 10:09 AM   #11
Shoebox
Shoebox's Avatar
Mike & Tony, NY
Thanks for the responses and logical suggestions to diagnose. I'll be taking some time from my ongoing '51 shoebox project to find this speedometer issue. Will verify power/ground to speedo before disconnecting from GPS module. I did try pushing the program button with no response. I will report back at some point. Thanks.
32 Ford roadster
39 Mercury Towncar
Old 10-09-2023, 06:14 AM   #12
Bored&Stroked
Bored&Stroked's Avatar
BTW, nice looking dash!
Old 10-09-2023, 08:02 AM   #13
Shoebox
Shoebox's Avatar
Thanks Dale.
32 Ford roadster
39 Mercury Towncar
