Old 10-02-2023, 02:58 PM   #1
40ford
40ford's Avatar
Default Cam Shaft Bearing Size:
Engine builder told me he ran into a problem he had never seen.He told me the cam shaft bearings he always used fits my cam but are two small for the block?It is a stock 8RT out of my 1952 F-1.Are there more than one size cam bearings for a 1948-1952 block?
40ford is offline   Reply With Quote
Old 10-02-2023, 04:21 PM   #2
Pete
Default Re: Cam Shaft Bearing Size:
I have seen that a couple times in the past.
I figured it was a factory salvage job of a block that something was wrong with.
I would do some close checking before using that block. Check the center line distance between cam line and main line end to end.
Cam bearings can be made from bar or tubing stock out of aluminum or bronze.
Old 10-02-2023, 04:42 PM   #3
Jim Brierley
It was common in the old days to use .010" undersize bearings, especially on a reground cam.
Jim Brierley is offline   Reply With Quote
Old 10-02-2023, 06:24 PM   #4
Pete
Right, we still do that quite often but oversize on the block is not very common.
We do it for roller, extreme lift and radius lifter cams.
Old 10-02-2023, 07:07 PM   #5
KiWinUS
KiWinUS's Avatar
Probably.080 over on block. Not common but they are out there. I have a few sets of bearings. They are difficult to find.
KiWinUS is online now   Reply With Quote
Old 10-03-2023, 11:37 AM   #6
svm99
All Ford parts in Campbell CA has some of the oversize cam bearings, OD is larger.
408 378-1934.
Good luck Paul J.
svm99 is offline   Reply With Quote
Old 10-03-2023, 01:40 PM   #7
1948F-1Pickup
1948F-1Pickup's Avatar
The oversized cam bearings pop up on eBay from time to time. H&H had to put a set in my 239 when they did it last year.
1948F-1Pickup is offline   Reply With Quote
Old 10-03-2023, 04:50 PM   #8
Yoyodyne
Yoyodyne's Avatar
Is there a Bronze alloy that works better than others that you can recommend?
Yoyodyne is offline   Reply With Quote
Old 10-04-2023, 03:44 PM   #9
Pete
I have always used aluminum.
In most case the companies that make the material in question will have engineering data and recommendations available.
Old 10-04-2023, 07:01 PM   #10
Yoyodyne
Yoyodyne's Avatar
Do you have a preferred aliminum alloy? I need to do something similar, I'm not just being curious.
Old 10-04-2023, 07:09 PM   #11
Pete
I have had excellent success with 75T6. This is for full pressurized applications only.
I have used Oilite bronze for drip, wick or splash lubed bearings.
Old 10-04-2023, 07:57 PM   #12
Yoyodyne
Yoyodyne's Avatar
Thanks Pete. There's just nothing as good as advice from someone who has done it!
Old 10-04-2023, 08:00 PM   #13
Pete
You are welcome.
Old 10-05-2023, 04:31 PM   #14
Bored&Stroked
Bored&Stroked's Avatar
I'm with Pete . . . have seen 7075 T6 used to make custom cam bearings on some special engines at my machine shop. I've also seen guys do this when they've bored out the front 2 flathead cam bearing bores - for camshafts with much larger lifts that can be achieved with a stock journal size.
