Old 09-30-2023, 12:13 PM   #1
whatdoyouwant
Default 8ba question
I will not bore you with all that I went through with this engine but here is my question. I obtained this engine with a 4" crank, racing pistons, and a 400jr cam. No heads or intake. I put a stock intake and stock 8BA heads on it and promptly bent 15 out of 16 valves. It would sort of run on 5 cylinders. After taking all apart, I find I have sbc valves. The exhaust are 1.5" and the intakes are 1.6". After getting new valves and different heads with more valve pocket clearance, and doing a little modification it is again running. It runs good but I don't like the sound out the exhaust. With the other stuff different to the engine, can I just put in a stock cam? This car will never do more than cruise the streets of town. I forgot, it has adjustable lifters.
whatdoyouwant is offline   Reply With Quote
Old 09-30-2023, 12:23 PM   #2
alanwoodieman
Default Re: 8ba question
does it have the exhaust dividers between 2/3 and 6/7? if not put them in and see if that changes the sound. it seems like you have exhaust valve overlap with such a high lift cam
alanwoodieman is offline   Reply With Quote
Old 09-30-2023, 01:47 PM   #3
cadillac512
cadillac512's Avatar
If the lope in the exhaust at idle and low speeds is what you don't care for, then yes...install a stock cam. It'll work fine and will idle smooth. The adjustable lifters should accommodate the stock cam.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 09-30-2023, 02:02 PM   #4
19Fordy
19Fordy's Avatar
"With the other stuff different to the engine, can I just put in a stock cam? "
Read this BEFORE you decide to install baffles.
https://www.fordbarn.com/forum/showthread.php?t=51343
If you need baffles, I have a brand new set I never used. I sent you a PM.
Old 09-30-2023, 03:34 PM   #5
Ol' Ron
Ol' Ron's Avatar
The 400jr is a very good track cam, but it's long duration make it a poor street cam. But the sound is great. Ran one for a few years, worked quite well. Replaced it with the Erson D-410
Gramps
Old 09-30-2023, 09:14 PM   #6
tubman
tubman's Avatar
If you decide to replace your cam with a stock unit, try to get a Mercury cam (8CM, 0CM, or EAC).
I did and I like everything about it.
Old 09-30-2023, 10:10 PM   #7
cas3
I agree, ^^^ merc cam is a good stock unit. A little more low end torque as the automatics were coming in, and the merc was a heavy car. A local cam grinder near me
had a bin full of them for me. Barry Cam , Plato Minnesota
Old 10-01-2023, 07:41 AM   #8
solidaxle
solidaxle's Avatar
Back in the day, when pulling into a drive-in, Hot rodders would pull out the choke to achieve that lumpy sound. It made it sound like they had a hot cam.
solidaxle is offline   Reply With Quote
Old 10-01-2023, 08:43 AM   #9
whatdoyouwant
Thanks for all the help. I think I will go with a stock can rather than baffels. Since this is in a 48 Mercury, I will try to find a Merc cam.
al
Old 10-01-2023, 09:36 AM   #10
tubman
tubman's Avatar
'48 Mercury? I thought this thread was about an 8BA. If it truly is a '59A, then Ford or Merc cams are the same as far as I know.
Old 10-01-2023, 09:48 AM   #11
Ronnie
Ronnie's Avatar
Isn't that be Berry Cam
Ronnie
Ronnie is offline   Reply With Quote
Old 10-01-2023, 10:38 AM   #12
whatdoyouwant
Yes it is an 8BA engine, but I have installed it in a 48 merc
Old 10-01-2023, 05:56 PM   #13
cadillac512
8CM in my '41 Merc as well. It's a good swap. Mine has the 8CM Merc cam and is perfect for the way I use it. Strong but good manners.
Old 10-02-2023, 08:55 AM   #14
Ol' Ron
Ol' Ron's Avatar
I really don't think you could feel the difference between between any of the various 8bA style cams. Compression and carburetion. also have an efect on performance. Personaly I like the EAB cam, But it's the only stock cam I ever used.
G
