Old 09-25-2023, 10:05 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default Garage lift
I have an 8’ ceiling and a 33 Ford. The maximum I can lift the car is 3’. Anyone know of a lift/hoist than can accommodate my limited space needs?
Tim Carlig
dean333 is offline   Reply With Quote
Old 09-26-2023, 06:51 AM   #2
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: Garage lift
There is a scissor style lift that is like a two post lift in how you get the frame set to be lifted but without the posts. Good for brake jobs, tire stuff and the like. However, anything under the center of the car that needs repair is hindered by the very nature of the like.
Google it and see if will do most of what you want to do.
The next solution are ramps that used to be available - they are propped up at the front and you onto onto it and jack it up in the back for about 20” clearance. This is the opposite of the scissor lift in that there is no obstruction underneath but you would still need a floor jack for things where you would need to remove a wheel, brakes, etc. Google this and see what you come up with as well ….
Good luck ….
TomT/Williamsburg is offline   Reply With Quote
Old 09-26-2023, 07:03 AM   #3
Ray in La Mesa
The "old time" solution was to dig a trench in the yard & drive over it.
Ray in La Mesa is offline   Reply With Quote
Old 09-26-2023, 07:14 AM   #4
jackson
I have this lift:
https://www.kwik-lift.com
It requires a floor-jack to lift the rear. I park my car on it when I don't need to get under the car. I just moved... no longer need my Qwik-Lift. It comes apart, will fit in a pickup truck.
1950 Mercury mild custom. Original flathead, re-built, bored .040 over, Max-1 cam, Offy heads, Edelbrock super duel with Stromberg 48s.
jackson is offline   Reply With Quote
Old 09-26-2023, 07:55 AM   #5
rockfla
rockfla's Avatar
IF you want to get fancy and have the $$$$
Old 09-26-2023, 09:21 AM   #6
PeterC
PeterC's Avatar
Both Kwik Lift and Quick Jack are good solutions - I have the Quick Jack as it is frame lift and frees up entire suspension and under car for servicing! Both are excellent for low garage ceilings.
https://www.kwik-lift.com/product/kw...-full-package/
https://www.quickjack.com/?gclid=EAI...SAAEgJgOvD_BwE
File Type: jpg A432C4F4-CB95-4C56-BE07-0E762760F826_1_201_a.jpg (40.1 KB, 46 views)
PeterC is offline   Reply With Quote
Old 09-26-2023, 10:59 AM   #7
38bill
38bill's Avatar
I too have a Kwik Lift. Affordable and works great if don't mind laying on a creeper under the car. With a maximum 3' lift available you will be working on your back anyway. I purchased mine second hand and I still see them for sale used every now and then. They usually came with one cross plate but 2 would be better. Wheels were another option. I just put mine on HF tire dollies when I want to roll it around.
38bill is offline   Reply With Quote
Old 09-26-2023, 01:57 PM   #8
dean333
dean333's Avatar
Kwik lift ceased production a year ago due to lack of steel. If anyone knows of a used Kwik Lift for sale, I’m interested.
Tim Carlig
Old 09-26-2023, 06:27 PM   #9
Tony, NY
MaxJack used to be real popular over at the Garage Journal. Portable 2 post lift. https://www.maxjax.com/?gclid=CjwKCA...BoCLk0QAvD_BwE
Tony, NY is offline   Reply With Quote
Old 09-26-2023, 06:33 PM   #10
Pete
There are 2 viable solutions for your problem
1 - Put in a pit.
2 - Raise the roof.
A pit is MUCH easier because it does not have to be done quickly to keep the rain and locusts out.
Old 09-26-2023, 06:47 PM   #11
51504bat
51504bat's Avatar
Don't even think about telling your insurance broker if you have a pit.
Old 09-26-2023, 07:08 PM   #12
paul2748
paul2748's Avatar
Pits are illegal in a lot of places.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 09-26-2023, 08:22 PM   #13
dean333
dean333's Avatar
Nice two poster Tony but twice what I’d like to spend ideally.
Tim Carlig
Old 09-27-2023, 06:13 AM   #14
corvette8n
corvette8n's Avatar
https://www.fordbarn.com/forum/showthread.php?t=256084
I have a set of quick jacks, I bought the 12 volt model, I even left my ‘41 on them thru the winter once. In Nov-Dec. time frame the Quick jack site usually has a $100 or more off promotion.
So far I’ve used them with my ‘41, a Lincoln MKZ, a Frontier, a Ford Focus, Camry, and I sure I missed a few other cars relatives own.
Old 09-27-2023, 08:37 AM   #15
51504bat
51504bat's Avatar
I emailed Kwik Lift if they had an ETA when lifts would be available again and their response was no ETA at this time. Doesn't sound promising.
Old 09-27-2023, 09:10 AM   #16
Krylon32
I'm kind of a dinosaur but I never figured out the advantage of a Kwik Lift when a floor jack with some good jack stands gets you to the same place. Kwik Lift is probably safer?
Krylon32 is offline   Reply With Quote
Old 09-28-2023, 03:50 PM   #17
38coop
Hey Krylon 32. I have the same lift as you. It's a wonder i am still alive with all the bumper jack lifts i used in my teenage years.
38coop is offline   Reply With Quote
Old 10-22-2023, 10:35 AM   #18
Shoebox
Shoebox's Avatar
[QUOTE=PeterC;2258212]Both Kwik Lift and Quick Jack are good solutions - I have the Quick Jack as it is frame lift and frees up entire suspension and under car for servicing! Both are excellent for low garage ceilings.
QUOTE]
I have a 4 post Bendpak lift which I love, but I have 2 projects and needed something better than the constant floor jack/jack stand shuffle. I saw this thread and liked the frame lift idea of the Quick Jack, saw it is a Bendpak product, and gave them a call. I was routed to the same gal I dealt with 4 years ago when I got the 4 post. I was given some nice "returning customer" consideration, and 3 days later Fed Ex delivered. So far I REALLY like it.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 10-22-2023, 12:05 PM   #19
BigJim394
Thanks for starting this thread
It has the kind of great info I had been looking for
BigJim394 is offline   Reply With Quote
Old 10-22-2023, 01:15 PM   #20
petehoovie
petehoovie's Avatar
[QUOTE=Shoebox;2264385]
QUOTE]
