#1 |
My 1929 was built in Canada and I am wondering if the Robertson thread pitch is US or Metric? I am missing some of the screws and need to order some replacements. If they come in US thread pitch, it will not be a problem finding them, but if Metric ??
#2 |
unless you are doing a Marc show car, why worry?
#3 |
Canada did not switch over to the metric system until the seventies. You should be safe with regular pitch.
#4 | |
The Robertson screws are not Metric on your 1929 Canadian car. They will be standard stuff like #8-32, #10- 24, #10-32..... just like you have on US cars. There was someone in US that was making reproduction Robertson screws, I don't recall the name. In our local hardware store I picked up brand new Robertson style stainless steel screws. I knew they were very slightly different and the stainless is a different color than Nickel. They were on the car in plain view for ten years and I wondered when someone would notice them as to me they were obviously wrong. The person that noticed them finally, was a Canadian Judge. He was the only one and he wasn't very close to the car but spotted them through a closed window. He went by them and said " you know those screws are wrong, I have a few left that are correct!" That's what I love to here! I was beginning to think nobody could see a difference. |
#5 |
Can anybody tell me the thread size for the screws that hold the rear window frame together for open cars, as I need to find a source for the Robertson version.
1928 Roadster (CA67) 1931 Deluxe Coupe RHD 1931 Victoria RHD Model A's don't leak oil they just mark their territory. |
#6 |
#7 |
Will do.
#8 |
I could also use some #5-40 cage, or just regular, nuts to repair my original window frame
#9 |
I haven't been able to find Robertson screws in anything other than #6, #8, #10, and 1/4. The cars take a #5 and #12, but I can't find them anywhere.
Yes, I have asked a LOT of people and always get the "I can find all the Robertson screws I ever need at the local store!" But, of course...never a size #12. I've even reached out directly to manufacturers, and...nothing. I can get 1000 made for 60 cents (US) each, but that gets to be an expensive hobby.
Member, MARC Current owner, 1928 RHD Australian-built Phaeton CA4752 "Felicity" Former owner, 1931 Victoria, 1929 Phaeton, 1929 Fordor |
#10 |
Interesting observation. I thought I was experiencing a manufacturing glitch when I discovered none of the hardware stores in my area carry #12 screws. I don't need Robertson, but blade or phillips #12 would be handy without buying little packages dedicated to a single application
#11 |
Can you re thread the #6 to get #5? What about making some yourself with your lathe? I guess the hard part would be to form the square hole. Probably better to modify the #6 screws.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 09-25-2023 at 04:06 PM. |
#12 | |
#13 |
So #12 is actually 12/64 size? Does that mean that #10 is 5/32 and #8 is 1/8, etc.? I am reaching for my calipers.
#14 | |
British Standard 3/16 - 24/32 Basic outside thread diameter is 0.1875" American Standard #10 - 24/32 Basic outside thread diameter is 0.190" American Standard #12 - 24/28 Basic outside thread diameter is 0.216" American Standard 1/4 - 20/28 Basic outside thread diameter is 0.250" |
#15 |
#16 |
Try Tacoma Screw Products. They have been able to get me some really oddball screws in the past.
Also, try gunsmithing supply places. That is a standard size gun screw. |
#17 |
Also check out McMaster-Carr. https://www.mcmaster.com/
#18 | |
starting with a "0" the major diameter is .060 add .013" for every number up "2" is .060 + .026 "4" is .060 + .052 this from 7th grade machining class, I guess schools are missing out now... J
As Carroll Smith wrote; All Failures are Human in Origin. |
#19 |
Interior Robertson screw kits for most of the A body styles are available from Mikes "A" Ford-able Maysville GA. WWW.mikes-afordable.com. Right there in USA
Robertson screws used in the Canadian A's are imperial /US system threads. Hope this is of help. Windy here in NZ. Happy Motoring |
#20 | |
See post #14
