Old 04-01-2011, 02:25 PM   #1
Gerard
Gerard's Avatar
Default ppg paint job nearly done
Just want to share my pride, the paint job " Maroon " done 3 coats wet in wet . My arm hurts like hell during the job the gun seems to get heavyer and heavyer. Not a single drip or run.
OEPS I GOOFED the first picture is not my car the one with masking on is mine.
Gerard is offline   Reply With Quote
Old 04-01-2011, 02:34 PM   #2
gerrald meacham
Default Re: ppg paint job nearly done
they are not runs. they are flow indicators when they happen
gerrald meacham is offline   Reply With Quote
Old 04-01-2011, 02:47 PM   #3
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Good job, I'm jealous!
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 04-01-2011, 03:02 PM   #4
TinCup
TinCup's Avatar
That's going to be one nice ride!
Good Luck
TinCup is offline   Reply With Quote
Old 04-01-2011, 03:09 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Seeing this give the rest of us hope!
Old 04-01-2011, 03:12 PM   #6
Brian-NJ
Nice!
Brian-NJ is offline   Reply With Quote
Old 04-01-2011, 03:43 PM   #7
Doug in NJ
Doug in NJ's Avatar
Congratulations! I know the feeling.
I got a few runs on my paint job, but only in the corners of the window reveals, where the horizontal and vertical passes of the gun overlapped.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 04-01-2011, 03:48 PM   #8
Ross/Kzoo
Ross/Kzoo's Avatar
Really looks nice. Probably better than when Henry did it originally.
Ross/Kzoo is offline   Reply With Quote
Old 04-01-2011, 03:59 PM   #9
Mitch//pa
kudos, nice job
Old 04-01-2011, 04:04 PM   #10
Bob/Kansas City
Bob/Kansas City's Avatar
Great looking job! Did you use PPG's acrylic lacquer on that?
Also what type of gun did you use?
I'm getting ready to paint mine and am trying to gather all the info I can before I start.
Thanks in advance for any tips you can share.
Bob
Bob/Kansas City is offline   Reply With Quote
Old 04-01-2011, 04:55 PM   #11
Gerard
Gerard's Avatar
Bob, I use a Dutch spray gun At least 35 years old but very well maintained . Before I start to do paint job I place a piece of wrapping paper Approx 2 feet by 2 feet flat on the wall dull side towards me. Then I adjust my spray pattern and paint quantity on the gun. ( test spray ) Then I turn the paper with the shiny towards me and repeat the process ( fine tuning ) I am then able to see the flow process on the paper. If satisfied I continue to do the job. Air pressure is around 60 pounds at the regulator and water trap. The pressure is less at the gun but never bothered to measure. The above discribed method worked fine for me over the years .
Paint is PPG concept acrylic .
To dilute the paint I use a so called DIN cup and measure the flow for the flow trough the spout in seconds and then I know I did it right. Din cups are not known to my knowledge in the USA maybe you guy's use something different. But I just loaned my DIN cup to a professional ( Roll's R guy ) he was amazed that something like that existed.I know for certain there are others who think differently about the way I do it. But the end results are counting only.
Old 04-01-2011, 05:23 PM   #12
Mike V. Florida
The paint sheet I have refers to a Zahn Cup. A stainless steel cup woth a small whole in the bottom. You dip the cup in the paint and measure the time it takes until the paint breaks the stream.
With the Din cup, I think you wait until the cup is empty.
Old 04-01-2011, 05:29 PM   #13
Gerard
Gerard's Avatar
you are right Mike. we europeens don't like full glasses we empty them as quickly as possible. LOL.
Old 04-01-2011, 07:20 PM   #14
Joop
Joop's Avatar
WAT EEN SNOEPJE!
Joop
Joop is offline   Reply With Quote
Old 04-01-2011, 08:17 PM   #15
RTC1930
RTC1930's Avatar
I love that first car! LOL... Yours looks excellent too. I hope everything went smooth.
Bob NJ
"Fix what's broken"
RTC1930 is offline   Reply With Quote
Old 04-02-2011, 09:56 AM   #16
JBR
JBR's Avatar
Beautiful job. If you ever get to Iowa, I'll be glad to let you paint my 29 pickup.
JBR is offline   Reply With Quote
Old 04-02-2011, 10:18 AM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
Your car looks great. Please come and take over this messtoration I got involved in!
I'm a lot further along than this picture shows, but still have a long way to go.
Old 04-02-2011, 11:20 AM   #18
Roadster62
Roadster62's Avatar
Looks great, now you can start with a block, some soap, and some 1500 grit wet or dry paper.
Roadster62 is offline   Reply With Quote
Old 04-02-2011, 01:21 PM   #19
Gerard
Gerard's Avatar
No sanding anymore just a light buff to get a deeper shine but that's it.
Old 04-04-2011, 02:04 PM   #20
Bob/Kansas City
Gerard - Thank you for the information. The "old" high pressure way of spraying is what I've been used to doing but I've been looking at the HVLP guns lately and even the turbine systems with the warm, dry, oil free air they supply. it's been hard to try and find anyone that has painted a car with one to see how they actually perform. All the ads make them sound like the best thing since canned beer!
It looks like this old dog needs to learn a new trick!
Bob
