Old 09-17-2023, 05:31 PM   #1
crjohn
Default 1947 Super Deluxe V8 engine ground strap?
I have read that there should be a ground strap from the engine to the firewall on a 1947 super deluxe to make for a better starting engine. Does anyone have a photo (or good description) to show the original location, mine is no where to be found. I have purchased the strap and would like to place it as close to the original location as I can.
Thanks for the help!
John
crjohn is offline   Reply With Quote
Old 09-17-2023, 06:45 PM   #2
47fordguy
47fordguy's Avatar
Default Re: 1947 Super Deluxe V8 engine ground strap?
John
Here are two photos of the ground strap on my 47 Super Deluxe V8. Others can corroborate if it is the exact original location.
Cody
47fordguy is offline   Reply With Quote
Old 09-17-2023, 07:45 PM   #3
Kube
Super Moderator
Kube's Avatar
Originally Posted by 47fordkid View Post
John
Cody
This is correct.
Old 09-17-2023, 09:14 PM   #4
petehoovie
petehoovie's Avatar
John
Cody
Old 09-17-2023, 09:24 PM   #5
crjohn
Great photo's! Thanks so much!!! You rock!
Old 09-18-2023, 09:07 AM   #6
GB SISSON
GB SISSON's Avatar
I too am chiming in to say how good the photos are. The composition is just right too! Were they taken by an Iphone?
Old 09-18-2023, 09:38 AM   #7
Bill OH
I have a 38 Ford 221 that had a ground strap from the battery to the firewall and another ground strap from the firewall to the engine, all of which yielded a voltage drop of 0.35 volts.
Steel does not have the conductivity of copper. I removed the ground strap from the battery to the firewall and replaced it with a 24 inch 1 gauge cable with a copper eye terminal that I soldered on with silver bearing solder. I connected that cable from the battery to the ground strap that goes from the firewall to the engine. Voltage drop now 0.10 volts and the starter spins much faster. I have experienced grabbing the throttle rod on a 47 Ford that was hot - installed a ground cable from the battery to the engine. I might add that the 1 gauge copper cable that I used had a steel eye terminal that caused an additional 0.1 volt drop, hence used the copper eye terminal to remove that drop.
Bill OH is offline   Reply With Quote
Old 09-18-2023, 02:34 PM   #8
47fordguy
47fordguy's Avatar
Thanks! I took them with my Canon 190 IS camera which has a good flash to illuminate the engine bay.
Old 09-18-2023, 03:25 PM   #9
Veeder
I brought the positive (positive grd) direct from the battery to the block and had the strap(as shown) as well for the misc. stuf. I think it nade the world of difference
Veeder is offline   Reply With Quote
Old 02-11-2024, 03:14 PM   #10
Clrascoe
I am a new member and just saw this post. I see that the engine in the photo is green. Mine is also the same green. Someone at Ford told my father that was the correct color when we were rebuilding the engine back in the 70s; however, all the parts catalogues say the engine paint color is blue. Does anyone know what the color should be? My car is a "late" 47 super deluxe.
Clrascoe is offline   Reply With Quote
Old 02-11-2024, 04:41 PM   #11
RKS.PA
RKS.PA's Avatar
I believe the "correct" color is blue. (At least mine is!!)
RKS.PA is offline   Reply With Quote
Old 02-11-2024, 04:42 PM   #12
47fordguy
47fordguy's Avatar
blue is the correct color as far as i know. some parts of my engine are the wrong color (green)
No job is so important and no service is so urgent- that we cannot take time to perform our work safely.
-Bell System
Old 02-11-2024, 07:11 PM   #13
Graeme / New Zealand
Graeme / New Zealand's Avatar
Here's my one. Photo quality not as good as 47fordguy and you might ask "oi what's the accelerator linkage doing on that side?".....remember we are RHD down here at the "ass end of the world".
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 02-11-2024, 07:30 PM   #14
petehoovie
petehoovie's Avatar
Old 02-12-2024, 07:15 AM   #15
corvette8n
corvette8n's Avatar
Had to replace my braided cable it was all full of white corrosion and almost rotted through. I sprayed the new cable heavily with fluid film, hope this preserves it.
Old 02-12-2024, 09:01 AM   #16
pistonbroke
If your looking for functionality take your heavy braded or 1awg ground cable to a starter bolt . Electrons will always take the path of least resistance. You should still use your ground straps as they keep things like your gauges lights and heater in the loop but you will have little if any voltage loss to your starter. Of course this will not get you extra points from the judges at the shows. Tim
pistonbroke is offline   Reply With Quote
Old 02-12-2024, 12:44 PM   #17
Clrascoe
Thanks for the answers on the engine color. On the cables, where is the battery ground cable supposed to connect? I don't see that cable in the pictures above. I am looking to replace mine but the ones I see from the parts companies are too short to reach the manifold or cylinder head from the battery.
Old 02-12-2024, 11:18 PM   #18
FortyNiner
FortyNiner's Avatar
The battery ground cable is attached to a firewall ground stud on the PS (non-Austrailian versions) close to the battery box.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 02-13-2024, 06:16 AM   #19
ScubaChief60
ScubaChief60's Avatar
About the importance of this grounding strap... I had an engine replaced in a non Ford ( ) in 2018 and the installer failed to reconnect the engine to firewall grounding strap. The result was that when the engine was cold, it fired right up. When it was hot... you could not get it to fire up.
This happened about the third time outside a NAPA store... and one of the employees saw me with hood up and ventured out. He called his dad who had been an electrical engineer at GM and got him on the phone. Right away he said to check the grounding strap. It all had to do with more resistance as the wires and electrical system heats up... and the resulting flow of electrons being reduced. Same principal I understand as the purpose of the ballast resistor between the Ignition switch on my '35 Ford and the Coil. So that when the ballast resistor is cold, I'll get the full 6.7 volts to my coil and as it heats up then is reduced to I recall between 3 and 4 volts to the coil.
Anyhow... just things I have learned from advice and 'hard knocks'
ScubaChief60 is offline   Reply With Quote
Old 02-13-2024, 06:21 AM   #20
ScubaChief60
Oh... and I was advised too that same time to loose the braided strap and replace it with a proper sized lead just as you might use to connect your battery to the starter. Longer lasting and protected from the elements. ( From the mouth of that retired engineer. )
