09-11-2023, 04:56 PM | #1 |
Re torqueing heads
Put my 59-AB together re torqued the heads 3 times run to operating temp and torque the third time no more movement, should I do one more check after some miles are put on before the acorn caps are installed ?
Mike |
09-11-2023, 06:19 PM | #2 |
Re: Re torqueing heads
cant hurt no creep is always good
09-11-2023, 06:33 PM | #3 |
Torquing hot or cold ? S/B cold.
09-12-2023, 06:56 AM | #4 |
I retired from bucklenusting 10 years ago. Back then you only torqued a cold to the touch head.
BTW you only torque a loose fastener, after that, you're checking tightness. I do not use my TW's to loosen, they are not breaker bars.
..."they are only original once" |
09-12-2023, 11:34 AM | #5 |
09-13-2023, 09:20 AM | #6 |
A man should do what he thinks best! "The Duke" |
09-13-2023, 02:31 PM | #7 |
Did Ford require dealer to check torque? I have a dealer pre delivery book from a much later era to cover the year of a car I have, lot of interesting things in it.
