09-06-2023, 01:26 PM | #1 |
32 gas pedal
Seems I’m missing something
Thanks |
09-06-2023, 01:48 PM | #2 |
Re: 32 gas pedal
09-06-2023, 01:59 PM | #3 |
Re: 32 gas pedal
You are missing the "cup washer" (don't know official name for the metal cup that sits in the firewall insulation and allows you to tighten the stud down on the right). Stud also needs a nut obviously.
For the left, the cover is bolted to the firewall and it holds the throttle in place and keeps the shaft taught from the spring action. I also believe the one in your picture is for a 4 cyl. Last edited by Tim Ayers; 09-06-2023 at 02:11 PM. |
09-06-2023, 02:02 PM | #4 |
Re: 32 gas pedal
Hope this helps, not sure this is 100% complete but shows the cup washer, and stud mount you are for sure missing!!!
09-06-2023, 02:30 PM | #5 |
Re: 32 gas pedal
09-06-2023, 03:11 PM | #6 |
Re: 32 gas pedal
Charlie Stephens |
09-06-2023, 03:19 PM | #7 |
Re: 32 gas pedal
09-06-2023, 05:44 PM | #8 |
Re: 32 gas pedal
Yes mine is a 4 banger, I have the cup that goes inside just wasn't sure about the left cover
Thanks to all! |
09-06-2023, 06:01 PM | #9 |
Re: 32 gas pedal
You have everything that you need. Your photo sort of hides the threaded stud on the right side which passes through the firewall, insulator, cup washer before being secured with a hex nut and lock washer. A second pair of hands will make the installation a lot easier.
