09-06-2023, 06:40 AM | #1 |
Late 31 rear axle cotter pin question
HI Guys
I have a question on the rear axle cotter pins as I have everything else I just need to know the size of the cotter pins the original sizes as it's a original rear axle, but I have to put the original cotter pins in the shaft of the axle after the bolt is torqued to 125 ft. lbs. and I don't have the right size cotter pins for the rear axle so can someone please tell me what size the original cotter pins were originally. Reggiedog |
09-06-2023, 11:18 AM | #2 |
Re: Late 31 rear axle cotter pin question
1/8"x1"
09-07-2023, 03:22 AM | #3 |
Thanks
But I have found in a book where it says the original cotter pins where number 8 by 1-1/12" but I'm going to buy both of them and see how it all fits in there as 1/8" X 1" seams to small for it but I don't know at this moment so I will try both of them and see what fits in there. Thanks again Reggiedog |
09-07-2023, 04:41 AM | #4 |
Get something like this and choose the one you like:
https://www.amazon.com/Neiko-50454A-...82&sr=8-5&th=1 |
09-07-2023, 07:33 AM | #5 |
if the cotter is too long, just snip it off.
I think 125 # is too much. 80-90# is fine, then tighten until the cotter drops in which will be around the 100# range. The tapers should be clean and dry. |
09-07-2023, 01:23 PM | #6 |
72035-S is 1/8" x 1" cotter. |
09-09-2023, 03:38 AM | #7 |
Thanks,
I found what key was suppose to be in there thanks' anyway. Reggiedog |
